| Rear axle load or weight on it... | |
theGerg
| Subject: Rear axle load or weight on it... Sun Mar 31, 2013 1:24 am | |
| Im designing a box extender, and was hoping someone knew what the weight on the rear axle for a 700 was...or close to it. Would it be about half of the average wet weight of 1200lbs? Or is it more front end heavy? Just curious if anyone has put the rear of their rhino on a scale... | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 4:27 pm | |
| The more I think about it, it seems to be 1/2 and 1/2. | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 6:01 pm | |
| Close to 50/50,55.1% rear,44.9% front,I notice this when ever I get air the Rhino wants to nose dive. | |
theGerg
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 6:54 pm | |
| - 123.bert0621 wrote:
- Close to 50/50,55.1% rear,44.9% front,I notice this when ever I get air the Rhino wants to nose dive.
Then there is something wrong with your numbers...if the front is lighter its not gonna nose dive. | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 6:59 pm | |
| the front is lighter thats why the springs are heavier on the rear...shocks will make it nose dive | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 7:21 pm | |
| I guess I still have a lot to learn,oops. I think that I will try adjusting them and try it.
Last edited by 123.bert0621 on Sun Mar 31, 2013 7:28 pm; edited 1 time in total (Reason for editing : wanted to say more.) | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 8:15 pm | |
- I guess I still have a lot to learn,oops. I think that I will try adjusting them and try it.
do you have the sport shocks
theGerg
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 9:07 pm | |
| apparently I am the one with lots to learn...so the rear is heavier...so I should be building to a spec of about 60% of total weight for my main frame, and I will have underside and cable supports as well, just trying to sort out the size of steel tubing Im gonna need to use. Once its all done I'll show you guys some pics, it will be pretty sweet. | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 9:31 pm | |
| So your extending the whole frame? | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 10:01 pm | |
Yes I do.
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 10:22 pm | |
| turn the bottom adjustment on the rear shocks in one turn...this will help alot | |
| Subject: Re: Rear axle load or weight on it... Sun Mar 31, 2013 10:26 pm | |
| Thanks James I'll try it next weekend, going to try one click at a time, to about 12-15 see how it feels.
Last edited by 123.bert0621 on Tue Apr 02, 2013 6:44 pm; edited 1 time in total (Reason for editing : looked up some info) | |
theGerg
| Subject: Re: Rear axle load or weight on it... Mon Apr 01, 2013 1:02 am | |
| - CustomizedRhino13 wrote:
- So your extending the whole frame?
no its just a drop in rack to support the rear tires of the rhino so I can pack it in my short box truck. I will incorporate a hitch within a hitch design so I can still pull a trailer if I desire, but will have bottom supports that tie up to the rack from my hitch, as well as cables that clip onto my tailgate studs...I will remove the tailgate for this, and the whole thing will mount into my 5th wheel hitch runners that are bolted to my frame in the box. something like http://www.pdsfabrication.com/GateSaver.html but better | |
| Subject: Re: Rear axle load or weight on it... Mon Apr 01, 2013 1:55 am | |
| Oh I see, that makes sense now, don't want to trust those tailgate cables on an expensive machine. | |
| Subject: Re: Rear axle load or weight on it... | |
