Subject: Sheave Is HERE !!!!!!!!!!!!! Mon Apr 01, 2013 8:49 pm
This, my friends, is the new and improved 660 sheave from JBS !!! And it's at my house !!!!!!!! Oh Yea !!!!!
Man am I pumped ! This thing has shinny spots(machining) in some really cool places. Hopefully I will get it installed this week and give You guys an idea of what it does !
WOW ! Thanks Hotrod !!!!
Snorhino
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Mon Apr 01, 2013 8:58 pm
Monday's not so bad after all!!
meats
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Mon Apr 01, 2013 9:19 pm
mondays are great i got mine too
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Mon Apr 01, 2013 9:20 pm
looks like the UTV stink sheave.... ...keep us posted!
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 2:39 pm
Got it installed ! Havent got to go for ride yet, but I did work it back and forth a few times to make sure I got it in right.
Randy3451
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 3:18 pm
Looks good! Which spring and size weights did you go with?
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 3:43 pm
Orange spring and 16 gr. the same as what I had.
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 3:53 pm
Did you ride it yet? Why did you not just mill out the webbing on your old one, to many miles?
Randy3451
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 6:46 pm
Why the orange? What's the difference in it and the others, like the gold?
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 6:49 pm
i think its cus he has a 660
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 6:58 pm
Looks good,i just did the 660 mod to my jbs sheave the other day and it has alot better bottom end,now the belt will just about rub the cover! how does yours do on hills with the 16 gram ods,and whats your top speed?also what size tires are u running?
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 7:00 pm
I just asked James whats the best for trail riding.
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 7:01 pm
How did you measure or did you just eyeball it?
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 7:07 pm
I just took my sliders off my camplate and slid them down in the sheave where they would sit,then marked it with a sharpie,then i put an endmill bit in my drill press and took around 40,000ths of matterial out...done!! worked great!!
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 7:31 pm
Thanks!!!
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 8:03 pm
looks great man hope to get to install mine tomorrow or sat, hope mine goes as well as yours
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 8:30 pm
Just make sure the splines line up so you don't strip'em and hold the camp,lte tight so the weights don't flip over. Videos help the best. Good Luck you should be fine!
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 10:43 pm
Got it all sowed up and took it around the block a couple time tonight. Didn't hammer on it yet cause my neighbors have guns !!!
I really wished I could explain all about this new improved sheave but it is really over my head. Here are a couple things I have found with it.
First, You can see in this pic that the sliders have been riding on the fins of the sheave, not the weights like they should have been
After seeing this, I put the cam plate back in and picked up sheave and shook it. Just as I thought, you could here the weights rattle. Took camplate out cleaned everything up and installed in new sheave - shook it - no rattle - camplate is now setting on the weights !
James has made this to where it will allow for wear and still perform for years to come. Wish I could explain all of this but would take a month of Sundays to write it all down.
More to come. hopefully get a good long ride in this weekend.
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 11:17 pm
You explained it pretty good. So what I get out of it is that there is a millimeter or so gap between the cam plate and the weights but when you mill it out of the webbing it will be flush. Can this be fixed by just buying a 660 cam plate? Whats better about the 700 cam plate compared to the 660's? Thanks!
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Thu Apr 04, 2013 11:38 pm
Thats a good question ! Seems like was matter of if You had a 660 cam plate, there was some clips You had to get to use greasless sliders or just get a 700 plate which was suppose to be better. How I don't know .
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Fri Apr 05, 2013 11:08 am
Bump.
Subject: Re: Sheave Is HERE !!!!!!!!!!!!! Fri Apr 05, 2013 4:22 pm
The 700 cam plate is alot stronger than the 660,if you look at where the sliders go on the cam plate on both of them you will see,the 700 is alot beefier in that area.i know of 2 people that had the 660 plates wear the sliders and that alowed the plate to twist and bust out the dividers that are between the weights,ruined the sheaves!...get the 700 cam plate for sure!
