| full 2 seater cage that allows bed to tilt | |
+4chuddly Kenny G CUSTOMIZEDRHINO13 TNTJ 8 posters |
TNTJ
Posts : 8 Join date : 2013-03-15 Location : tennessee
| Subject: full 2 seater cage that allows bed to tilt Wed Apr 03, 2013 11:48 am | |
| I thought I'd post and see if anyone is running a two seater roll cage that allows the bed to tilit. pics, or info on who may be a good source to to check out would be appeciated.
I would love to keep the J-strong top I currently have, but not sure it would be compatible with an after market cage | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 03, 2013 11:57 am | |
| I think bumpers has his and it still dumps. Its pretty badass! | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 03, 2013 4:32 pm | |
| TNTJ, I'm running a custom 2 seater that you can still use the dump with. You do have to disconnect where there are 4 quick connects between the main cage and the rear cage. I got mine from a dude out of Cali, that had someone build it for him. Hex-head and drop 8 bolts and she'll dump. You can check it out under 'pic of your ride'.
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 03, 2013 4:40 pm | |
| TNTJ, Look under Kenny G's Bitchin Trail 450; the forum site has the pic all chopped but do can still get a view. I left the head rest bars on for the seat belts and putting and Ryder dust blanket on her, it will need them for support. The back view you can see where the two parts of the cage disconnect, about 3/4 of the way up the support bars coming down into the bed. | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 03, 2013 10:51 pm | |
| here is mine i built last weekend. I think im going to add some diagonals to it. I know its not the strongest in the world but it will keep the ground off their heads It only bolts to the bed so the cage dumps with the bed. i figure if i roll it and destroy something that is an acceptable loss as long as it protects anyone in the back. Im willing to rebuild for the convenience of the dump bed | |
TNTJ
| Subject: Re: full 2 seater cage that allows bed to tilt Thu Apr 04, 2013 2:14 pm | |
| - CustomizedRhino13 wrote:
- I think bumpers has his and it still dumps. Its pretty badass!
I went over to the other forum and found pics. thanks. - Kenny G wrote:
- TNTJ, Look under Kenny G's Bitchin Trail 450; the forum site has the pic all chopped but do can still get a view. I left the head rest bars on for the seat belts and putting and Ryder dust blanket on her, it will need them for support. The back view you can see where the two parts of the cage disconnect, about 3/4 of the way up the support bars coming down into the bed.
Thanks Kenny. I found the pics, but do you have any showing how the cage hits the bed? nice rhino BTW! | |
| Subject: Re: full 2 seater cage that allows bed to tilt Thu Apr 04, 2013 7:28 pm | |
| TNTJ, I'll see about taking some pics if you need to see. But basically the arms that drop down into the box attach behind the wheel wells through the floor of the bed. The arms that run vertical with the bed quick lock into the cage bar running across the front of the bed side to side. I'm going to be working on the bike this weekend and I'll post something for you to see. It's a nice setup. | |
TNTJ
| Subject: Re: full 2 seater cage that allows bed to tilt Fri Apr 05, 2013 9:10 am | |
| Thanks Kenny. I can't wait to see more. | |
| Subject: Re: full 2 seater cage that allows bed to tilt Sat Apr 06, 2013 8:18 pm | |
TNTJ
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 1:57 pm | |
| Thanks Kenny. I like those qucik connects. any issues with those rattling or not wanting to join together? Alos do you have pics from the rear so I can see how you cut the bed to allow the cage to tie to the frame? | |
Bumpers
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 2:55 pm | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 3:07 pm | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 3:55 pm | |
| That's not nice fool that's bad ass !!! | |
Bumpers
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 4:40 pm | |
| thanks guys... one day i plan to build anther and get rid of the bed and change it up some... i would like it to sit lower but i'm 6'6" and i have 3" or so of clearance with a helmet on so i wont ever hit my nogin | |
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 11:30 pm | |
| Nice setup Bumpers. I've got to dismantling my cage for the dump action to work, the cage is attached into the back bed support bar that runs across the under-side of the bed; as your bed just slides away from any support in the back. Yours makes it much more handy for the quick dump usage. | |
Bumpers
| Subject: Re: full 2 seater cage that allows bed to tilt Wed Apr 10, 2013 11:36 pm | |
| I still need to drill a hole or two and I had planned on putting some pins or somthing in the bed through the plateon the bottom of the cage so it will help hold it steady were I to slam it hard on the rear part of the cage | |
| Subject: Re: full 2 seater cage that allows bed to tilt Fri Jul 05, 2013 12:46 am | |
| Bumpers, that is a hell of a nice cage. I've been thinking about doing something with mine soon. Maybe chop what's already there, and add something to the rear. I want to come up with something that will let the bed dump. I like how easy it is to clean under the bed, and the inside of the bed itself when it's dumped. | |
| Subject: Re: full 2 seater cage that allows bed to tilt | |
