| What kind of tire pressure are you running, and why? | |
+14thekevin lost|concept Snorhino REDRHINO64 Garnog varmint10 Firefighter scottwv Pokahpolice madmax 1 Jet Hump hymarker Kenny G 18 posters |
| Subject: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 12:47 am | |
| Looking for some feedback on tire pressure, tire wear and why you think running the pressure you do, gives you the best performance. Is there any safety issues you feel has to do with tire pressure. Personally, I run about 14-15 psi in the 27X14 Mudlites on my bike. Handles well on the hard pack trails and has less sway going through the corners. I think less pressure gives me better traction in soft materials and if I'm going out to play in the mud/snow I'll drop the pressure down to around 10-11 psi. I never have ran real low pressure as I'm not sure how the spongy tire would hold up if I got stupid with low pressure in the tires. You know Cowboying? | |
hymarker
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 1:25 am | |
| Summer time i run about 15 rear and 17 front. Winter in the snow i run almost flat all around. Have popped the bead a couple times, but the lower the pressure, the bigger the footprint and the more traction. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 3:58 am | |
| I used to run 9 all around on the rzr s I had, even on fast trails. Considering they were 26s on a slightly wider machine with a lower center of gravity than the rhino, I figured I better listen to James and run more air. (Hot Rod knows!) I'm running 12 now, and they seem to flex good on the rocks, and I haven't lost the bead on one yet. Rhinos just need a little more air than a rzr. I won't run less than 12 unless I know it's going to be a slow muddy or snowy ride all day. I don't think I could keep the tires on the wheels with less than 12 if I'm running hard. I prefer to run low as I think I can get by with for the most traction. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 6:31 am | |
| like hump, james recommened 12 psi and i run ITP bead locks with interco reptiles (12" rims) and believe me if they didnt come off during last weekends ride, 12 psi is good. i hit a ditch at speed and bent the tie rod on the drivers side front and then i lost it and ended up sideways going down hill on a real rocky trail. no problems other then i damn near pooped my pants going 40 and sliding side ways to a stop. whats that saying ???? "you just cant fix ------------stupid". my low jack light was on, so i wasnt drunk either. trying to run down a rzr xp. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 7:58 pm | |
| 27" mudlites around 12-14 in summer winter around 6-8 | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 9:11 pm | |
| I run 20lbs. I've seen several lost beads and blown out sidewalls at lower pressure. I like the way it handles and haven't had any issues so Im staying high. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 9:27 pm | |
| Poka, 20#, what type of tire are you rollin. Do you get a bounce out of the tires with the pressure that high. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 9:38 pm | |
| I don't notice any. I like the ride. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 10:07 pm | |
| When I first put the 'horns on mine , I put 6 & 8 in them (thats what I always ran in my quad)...James told me to run like 12 , and 14...kinda doubted runnin that much , so I did 10 and 12. Ran it like that for a while , then went to 12 , and 14....like more pressure WAY better !! It takes a couple of miles to get used to the rear ; but , after you run them like that for a while , you can instantly tell when you have a tire down ! | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 10:10 pm | |
| 15 psi all the way around. Steers better and doesn't bottom out as much. | |
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 10:58 pm | |
| Does any of you think you get a little more speed/sport out of the Rhino run higher air in the tires? Anybody noticing difference in tire wear? My tires seem to have wore like chit. Not sure if the Mudlite is just a softer rubber that doesn't handle the hard pack trail as well as other tires. | |
varmint10
Posts : 82 Join date : 2013-03-15 Location : Northern Calif.
| Subject: Re: What kind of tire pressure are you running, and why? Thu Apr 04, 2013 11:16 pm | |
| I run 25" Bighorns with 10 in front and 13 in rear. My riding is all types of terrain, packed roads, going thru the woods to get around downed trees, loose rock, snow, water crossing, never pooped a bead but I have been with many who have. I do get flats!! | |
| Subject: Re: What kind of tire pressure are you running, and why? Fri Apr 05, 2013 1:42 pm | |
| - Kenny G wrote:
- Does any of you think you get a little more speed/sport out of the Rhino run higher air in the tires? Anybody noticing difference in tire wear? My tires seem to have wore like chit. Not sure if the Mudlite is just a softer rubber that doesn't handle the hard pack trail as well as other tires.
I had mudlite xls on my 450, and I could see the wear after every ride. Hit the pavement for 4 miles and it just gave me the feeling that I was throwing $5 out on the road. They wear very quick. | |
| Subject: Re: What kind of tire pressure are you running, and why? Fri Apr 05, 2013 2:03 pm | |
| Really like the radial ride of the Mudlites but if they wear this fast I'll be in the poor house just keeping shoes on the Rhino. | |
Garnog
Posts : 46 Join date : 2013-03-10 Location : Moundtown, WV
| Subject: Re: What kind of tire pressure are you running, and why? Fri Apr 05, 2013 3:32 pm | |
| Mudlites on my Rhino lasted a little over 300 miles. A lot of hard pack riding. | |
| Subject: Re: What kind of tire pressure are you running, and why? Sat Apr 06, 2013 1:57 am | |
| Bighorns wear great compared to Mudlites and the stock tires. That's all I can compare because that's all I've ran on a sxs. I did like the traction of the mudlites in the really soft stuff. It would be nice to run something like that on another set of wheels durring the sloppy months. Just checked my psi again tonight, and changed them a little. I'm going to try 12.5 front and 13.5 rear tomarrow. I said I had 12 all around, but I had 14. Sorry for telling lies. LOL | |
| Subject: Re: What kind of tire pressure are you running, and why? Sat Apr 06, 2013 3:52 am | |
| Subject: Re: What kind of tire pressure are you running, and why? Sun Apr 07, 2013 7:14 pm | |
| Lookin at the mudlites today and the front rubbers are wearing faster than the rear... I've got a lot more weight towards the back; plus the locked rear-end which should cause more wear in turning, correct? If they last the summer I'll be lucky. Better start lookin for some 'hard rubber' tires. What has been standout rubbers for you guys? Need something not to heavy for the 450thy to handle. | |
Snorhino
| Subject: Re: What kind of tire pressure are you running, and why? Sun Apr 07, 2013 8:50 pm | |
| - Kenny G wrote:
- Lookin at the mudlites today and the front rubbers are wearing faster than the rear... I've got a lot more weight towards the back; plus the locked rear-end which should cause more wear in turning, correct? If they last the summer I'll be lucky. Better start lookin for some 'hard rubber' tires. What has been standout rubbers for you guys? Need something not to heavy for the 450thy to handle.
I have gotten good tread life out of my Terracross | |
| Subject: Re: What kind of tire pressure are you running, and why? Sun Apr 07, 2013 9:47 pm | |
| Bighorns run tall, that's why I went with 25s. They are not real heavy, there are others in the same size that weigh alot more. The 25s, and 26x9s are light compared to the wider sizes in the 26" and up. If I were you, I would go for the 25" original Bighorns. 450 should pull them fine. | |
| Subject: Re: What kind of tire pressure are you running, and why? Sun Apr 07, 2013 11:10 pm | |
| Thanks, I'll keep that in mind. I've got the 14" rims and the OG 12" rims still. Like the taller tire for the off-roading that I roll in. | |
lost|concept
| Subject: Re: What kind of tire pressure are you running, and why? Mon May 06, 2013 12:05 am | |
| - Firefighter wrote:
- Here is a couple pics of 26in Big Horns with 3000+ miles
Firefighter- What size bighorns are you running front and back? I was thinking about going 26x9s all the way around but I feel they will be too narrow for the mud. But the 25x10s seems so damn short to me. 26x11s all the way around seem like a bit much to me as well.. Im lost...go figure | |
| Subject: Re: What kind of tire pressure are you running, and why? Mon May 06, 2013 12:17 am | |
| I run 26x9-14 on the front and 26x11-14 on the rear. I thought about a couple different setups, but this one works so well, why change. | |
lost|concept
| Subject: Re: What kind of tire pressure are you running, and why? Mon May 06, 2013 12:19 am | |
| Yeah. My rims are set up so they are running the same stance. So I want to go with the same tire all the way around. I wish they just made a dang 26x10 that would be perfect! | |
| Subject: Re: What kind of tire pressure are you running, and why? | |
