| Steering wheel ergo's SUCK! | |
+3T.Rhino Pokahpolice chuddly 7 posters |
| Subject: Steering wheel ergo's SUCK! Mon Apr 08, 2013 7:53 am | |
| When im just kicking around the yard its not a big deal...but when i strap in with my 4pt harness and lock myself back reaching the steering wheel is a pain! Its angled up at a funny angle and its to far away causing me to reach for it and wear up and feel it much sooner than I should. I dont mind the seats but im not set on them either. Really i would just like to move the column a little and make it better but does anyone have any suggestions? | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 8:44 am | |
| Moving the steering column is going to be a big project. Moving the seat is much easier. They make some sliders that make the seat adjustable. | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 8:53 am | |
| Tilt wheel I have it on mine and love it. | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 9:07 am | |
| all you have to do put washers on the front bolts of the steering shaft and it will be lower and better...hump did it | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 9:44 am | |
| - T.Rhino wrote:
- Tilt wheel I have it on mine and love it.
Explain more about the tilt wheel. That sounds like EXACTLY what i want. But i dont want to spend a ton on it. James...i may do what your suggesting for the time being but a tilt wheels sounds real nice. But like i said i dont want to spend a ton on it. Most of the time im not strapped in so its not an issue 90% of the time. | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 11:09 am | |
| - WV Hot Rod Rhino wrote:
- all you have to do put washers on the front bolts of the steering shaft and it will be lower and better...hump did it
Yeah, I got the idea from over there at that stinking RF. Loosten the two bolts closest to the steering wheel a good bit, take the front ones out and stack about 3/8" worth of washers under the front of the mount and replace the two bolts. Then tighten everything. It's a real pain to get the washers lined up, but it's worth it. Lowers the wheel about 1 1/2". That don't sound like much, but it made a big diference. | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 11:12 am | |
| I purchased mine from side by side sports on the Internet and love it. I tried putting the washers under the front 2 bolts but it caused the steering to bind on me but that could be do to the power steering unit I have they have additional universal joints in them. But the tilt steering unit is very easy to install maybe A hour to do not bad at all but the price I thank is around $400 I thank you can cheak there site for A quote but if you decide to go with tilt you won't be disappointed. | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 11:16 am | |
| I was going to cut the mounts and re-weld them where I wanted them, but figured I would try the washers 1st because I didn't want the rhino down for 2 weeks. I wanna ride! | |
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 11:37 am | |
| Does anyone know how much i can tilt the current mount before the stock universal joint wants to bind? Cutting and welding is no big deal to me but i just dont want to do it twice if I dont have to. | |
Bumpers
| Subject: Re: Steering wheel ergo's SUCK! Mon Apr 08, 2013 12:44 pm | |
| Im really not sure... I guess i need to put some more washers in mine.. i put probly 1/4" worth in the rear of mine and it doesnt seem like it moved much at all | |
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 1:29 am | |
| - chuddly wrote:
- Does anyone know how much i can tilt the current mount before the stock universal joint wants to bind? Cutting and welding is no big deal to me but i just dont want to do it twice if I dont have to.
From what I could tell, it looks like it won't bind at all. The problem I see is that the steering shaft may need to be lengthened some if you try to keep the column inside the factory hole in the dash. As you raise the mount to lower the wheel, the wheel tilts toward the left with the stock length shaft. I'm talking about the shaft that goes from the rack up to the column. | |
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 1:48 am | |
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 7:02 am | |
| I thank the binding I spoke of will only happen when you have the power steering unit installed cause of the additional universal joint. But I still had no luck getting the right amount of tilt with the washers though. | |
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 7:51 am | |
| I think i may have found this weekends project......I dont mind lengthening the shaft. I think i should be able to cut and rework the whole thing in 2-3 hours. To me thats time well spent to have good seating/ergonomics and not strain something while riding. I will take some pictures of it when i do it and show what/how i did it all. | |
Bumpers
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 11:00 am | |
| This thread got me thinking yesterday and i only had about a 1/4" of washers before so i added a few more probly 3/8"-1/2" or so. I cant hardly tell any difference maybe tilted down just a hair but nothing big. | |
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 11:33 am | |
| would you guys be interested in seeing how to do this? Im sure i can make it happen fairly easily. | |
Bumpers
| Subject: Re: Steering wheel ergo's SUCK! Tue Apr 09, 2013 5:27 pm | |
| if you come down much lower with it a removable steering wheel wouldnt be a bad idea.. i have one and use it every now and then if i cant get the door open or somthing | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 1:03 am | |
| With the washers, mine didn't end up anywhere near where I wanted it to be. It is a little better though. I also shimmed the front of my stock seat up 1/2" because my legs were not even touching the front 1/2 of the seat.
It looks to me like the sqare tube that the steering column mount welds to would have to be raised up if you want to keep the column in the factory dash hole. That's the part that made me put it off for a while. I want to do it no matter what it takes, because I'm going to keep this thing for ever. I really want to make it the best it can be for me.
Chuddly, keep us updated on this project. Pics are nice also. | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 7:22 am | |
| i played around with it a bit last night and its much better. But its still not EXACTLY what i want. I took the stock column out and elongated the mounting holes. This made it so i could put more spacers under the front of the column. Like i said its much better but not perfect yet...i really just want it to come straight back from where it is. here is a picture of the modified column. I might drive it like this for a short time and see how it does. Or I might cut it up and go it the way i want to this weekend....ya just never know | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 7:28 am | |
| I have a spare one of those if you want one to experiment with. | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 9:15 am | |
| - T.Rhino wrote:
- I have a spare one of those if you want one to experiment with.
OHH really? I would love to have a spare one to play with. I actually think i can make a "kit" for people to move the column down and toward the driver. How much would you have to have for your spare? | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 9:54 am | |
| Does $25 plus shipping sound ok. | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 9:55 am | |
| Or do you have anything you would want to trade for it. | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 10:00 am | |
| what are you looking for on trade? I have stuff.... | |
| Subject: Re: Steering wheel ergo's SUCK! Wed Apr 10, 2013 10:05 am | |
| PM sent. Owe I know you do that's why I asked you have some pretty cool looking stuff. | |
| Subject: Re: Steering wheel ergo's SUCK! | |
