| Rhino Just Dies | |
+5CUSTOMIZEDRHINO13 Bumpers WV Hot Rod Rhino Firefighter brewis 9 posters |
brewis
| Subject: Rhino Just Dies Mon Apr 08, 2013 1:42 pm | |
| I've had this problem for about two years on my 07 660. Starts fine, hot or cold but just dies when idleing. It goes from running to idle and sometimes it dies within a minute sometimes it may idle ok for a couple of minutes. It seems to do it less if the choke is out a little. I put on a new fuel pump last year, rutting rhino, but it didn't help much after it dies when I pump it up it starts right up. It runs great otherwise. Any suggestions? Thanks | |
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 1:51 pm | |
| Good question ! my 07 660 will only idle for about 5 min then die. Then choke to start. I have alba pump with weller racing dual hose kit. My guess has always been that it doesnt have enough vacuum to run the pump very long. | |
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 2:42 pm | |
| turn the idle up just a little.. | |
brewis
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 6:33 pm | |
| Okay, thanks for the idea. I'll try it when I get everything put back together. Spring maintenance. | |
Bumpers
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 6:58 pm | |
| mine did it too and turning the idle up a hair will normally fix it like james said... but i like mine quieter at idle so i deal with it haha... I dont usually stop long enough for it to go dead lol | |
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 11:27 pm | |
| x2 turn the idle up and make sure your air filter is clean mine was doing the same thing. | |
| Subject: Re: Rhino Just Dies Mon Apr 08, 2013 11:29 pm | |
| the vacuum "signal" from the carb is weak if your idle is too slow. x2 on the clean air filter. | |
brewis
| Subject: Re: Rhino Just Dies Fri May 10, 2013 3:17 pm | |
| I adjusted the idle which works, but it in my opinion is too high, it slams into gear when shifting. So I put a slight restriction, small nut, in the fuel pump return line and turned the idle back down. Seems to work soooo far. | |
| Subject: Re: Rhino Just Dies Fri May 10, 2013 3:18 pm | |
| - brewis wrote:
- I adjusted the idle which works, but it in my opinion is too high, it slams into gear when shifting. So I put a slight restriction, small nut, in the fuel pump return line and turned the idle back down. Seems to work soooo far.
Great idea ! Keep us posted ! | |
| Subject: Re: Rhino Just Dies Fri May 10, 2013 4:17 pm | |
| Subject: Re: Rhino Just Dies Fri May 10, 2013 7:58 pm | |
| Scott, Not to shoot down your idea but the fuel return nipple going back into the tank is already restricted to 1/16 inch. My experiance is that over time carbon builds up in the carb and the small holes delivering the fuel, And over time it gets to a point that just dosent run right. I rebuild more Carb's for bad running isues than anything else. Good luck. | |
| Subject: Re: Rhino Just Dies Fri May 10, 2013 9:05 pm | |
| dont want it slam in gear for sure...if it wasnt too low..check the carb like mike said | |
brewis
| Subject: Re: Rhino Just Dies Mon May 13, 2013 1:50 pm | |
| Okay, it ran pretty good over the weekend only dying once, stuck in the snow, on an up hill, idling. So should a good cleaning do it? Thanks....... OBW the radiator guards worked great, they kept the snow out of the radiator and held up to the severe snow pack. | |
| Subject: Re: Rhino Just Dies Mon May 13, 2013 4:46 pm | |
| Did you guys put in a primer pump? I have the same problem but I know thats the cause. | |
brewis
| Subject: Re: Rhino Just Dies Mon May 13, 2013 5:07 pm | |
| I have one. Do you think that's what is causing the problem? | |
| Subject: Re: Rhino Just Dies | |
| Rhino Just Dies | |
