In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests :: 2 Bots
broken tabs that hold rear diff Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
broken tabs that hold rear diff Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
broken tabs that hold rear diff Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
broken tabs that hold rear diff Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
broken tabs that hold rear diff Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
broken tabs that hold rear diff Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
broken tabs that hold rear diff Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
broken tabs that hold rear diff Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
broken tabs that hold rear diff Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
broken tabs that hold rear diff Vote_lcapbroken tabs that hold rear diff Voting_barbroken tabs that hold rear diff Vote_rcap
jaydub
6 posters
Go to page : 1, 2  Next
jaydub
broken tabs that hold rear diff Empty
PostSubject: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 10:00 am
Hey guys. My 30 inch zillas and Jbs sheave got the best of my rear diff mounts on my 05 660. I have the lsr bracket but the bolt that goes in to the diff sheared off. That's another story...... I welded it back up to where its usable, but I know im on borrowed time. I'm capable of making new mounts but I was wondering if anyone makes a weld on gussett kit or something along those lines. The round tubes are all rust free and strong. Just my tabs broke off.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 10:05 am
X2 on the question. Mine loosens up about every other ride.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 10:32 am
I did find a guy who makes new mounts. Can't find him anymore, so I'm sending James one to duplicate. Also, I suggest a diff support like the CRB that adds 2 additional mounting tabs.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 10:33 am
There are companies that make a rear diff support but i can't think of any right now. I have one on my rhino . I'll try to get a pic when i get home from work. I bought it used a while ago and I have broken it and welded it once.
http://www.trailbrightled.com
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 10:40 am
yamaha makes a kit to put larger bolts in it too ...i will get some
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 11:09 am
Let me know when You get them. I need one!
jaydub
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 11:19 am
I have a l s r support already. James, what would bigger bolts do if its the thin metal tabs that break?
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 11:22 am
Of coarse you know I need them mine is about to fall out even after me and you (James) tightend them up one ride later they where clunking every time I hit the gas.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:13 pm
What all is included in the kit. Bigger bolts will help as the diff case mounting holes are much bigger than the OEM bolts. That will help to keep the diff from moving side to side and egg shaping the diff holes and breaking tabs. Better cote the new bolts with anti seize!
I have fixed several already and a buddy just brought me another with broken mounts. Diff is loose and caused the drive coupler on the engine as well as the splines on the driveshaft to wear.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:21 pm
Check out the CRB diff support, it has 2 additional tabs to bolt the diff to. Google it and a great pic on the rf comes up. BRP is selling them now.
LSR makes great products( I just purchased one of their 2 seat chromoly cages), but their frame gusset only has one tab for the diff.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:24 pm
is it this one Steve ?
broken tabs that hold rear diff Yamaha12
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:31 pm
Yes, Thanks for posting the pic!
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:41 pm
That's like the one i have and broke it once. I think I'm just going to make my own and stronger
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:44 pm
Where did it break? Ive been beating the crap out of mine over 5000 miles and not one issue. Not even a loose bolt! Even magnufluxed it to see if it had any cracks, none.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:50 pm
I broke the tabs off that are bolted to the rear. One was cracked when i bought it (used) and i welded it. Then it broke again and i welded it again. So before it breaks again I'll make a new one. The ones that you buy are made to work with the X brace for the A arms. So I'll make one that goes straight back
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 12:52 pm
Just too much Horse power !!! Thats the problem with these Rhino's. HAHA
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 1:01 pm
Flimmy, time to hijack this thread. I'm looking for info on the Alba exhaust.
Have you noticed an increase in the bed temperature?
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 5:59 pm
Here is my diff support and you can see where I had to weld it. I plan on making the tabs longer and go back farther.
broken tabs that hold rear diff 20130409_160035_zps8538e2cf
onebuilder , I haven't had it out for a long ride since I put it on. But I don't have a stock bed anymore. The new bed is 3" above the frame. So it might have enough room to keep it cool plus its aluminum and that should help cool it faster.
broken tabs that hold rear diff 20130409_160241_zps10c84f0b
broken tabs that hold rear diff 20130409_160222_zpsc98aec30
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:02 pm
Flimmy, That diff support looks to be from UTV Crap. No wonder it broke!
Thanks for the reply on the exhaust.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:06 pm
I bought it used from a guy in Ga sometime early last yr. he was selling parts off before he sold his rhino.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:09 pm
In the picture showing you're bed and tire, is it the pic or do you have rear steer?
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:17 pm
Its just the pic , but I'd love to have rear steer I just think front axle and cv's wouldn't be strong enough. The bed is dovetailed so it makes it look a little different. It helps keep the bedsides off the trees
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:24 pm
broken tabs that hold rear diff 20130411
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:29 pm
Ok, their is a guy that has rear steer. He used the front arms/ hub on the rear. For steering he Fab'd a trim control from a inboard outboard marine pump and ram. I thought maybe you were him. I try and see if I can find him again.
PostSubject: Re: broken tabs that hold rear diff   broken tabs that hold rear diff Icon_minitimeTue Apr 09, 2013 6:38 pm
If I were to do rear steer I'd probably use a 12v Linear actuators to steer the rear.
» rear diff for a 2005 660
» rear diff
» rear diff
» Rear diff bracket
» rear diff brace
