Who is online? | In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? | |
MR.HAPPY
Posts : 13 Join date : 2013-04-12 Age : 59 Location : ILLINOIS
| Subject: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Fri Apr 12, 2013 1:01 pm | |
| When the new Crew SxS comes out in June, I'm thinking of using VDP's corner roll bar overhead mounted supreme speakers w/dome light units for Jeeps! Sony has a couple Ipod internal tray stereos w/52 x 4 that I'm thinking would work well with the overheads in the corners. Hoping it would not need a amp to kill a battery! Anybody try'd any of these speakers in a Jeep or SxS??? | |
| | | T.Rhino
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Fri Apr 12, 2013 3:40 pm | |
| I have not tried one myself but seen plenty in my friends rhinos the over head speaker units that is and they seem to work really well and without a amp but if you did go with a amp you should still be ok also if you want a little security you could hook it all up to a switch that totally kills the power to it when you choose to or add a second battery I have seen some pretty big system's here so it can be done without a problem. | |
| | | banchee6
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Sat Apr 13, 2013 8:51 am | |
| i think thats the same radio i have in my rhino... it plays for hours in mine and i can start it right up.... good product.... | |
| | | MR.HAPPY
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Sat Apr 13, 2013 12:22 pm | |
| I'm more wanting to know if anybody has used the VDP corner supreme wedge speakers... they are made for a Jeep, but I was thinking of using them on my new Crew in all 4 corners.
They fit just in the corner of the cage & have 1 little dome light, a tweeter & 6.5" speaker in each wedge. I think they should sound good in the overhead corners & the dome light would be handy for all passengers at night! | |
| | | banchee6
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Sun Apr 14, 2013 1:57 am | |
| good call!!!!!!!!!!!!!!!!!!!!!!!!!!!! | |
| | | MR.HAPPY
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Sun Apr 14, 2013 9:16 am | |
| You think it will work good??? Know anyone thats used the speakers? | |
| | | Snorider
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Sat May 25, 2013 1:01 am | |
| - T.Rhino wrote:
- I have not tried one myself but seen plenty in my friends rhinos the over head speaker units that is and they seem to work really well and without a amp but if you did go with a amp you should still be ok also if you want a little security you could hook it all up to a switch that totally kills the power to it when you choose to or add a second battery I have seen some pretty big system's here so it can be done without a problem.
so they sound good without an amp for hte sound bars? I have been kicking around getting one with a rear mount since I'm not getting rid of my overhead gun rack. but torn between the amped version and non amped. cause if the non amped version sounds great, thats what i'll get. sorry for the birdwalk on your corner speakers | |
| | | thePayne
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Wed Jun 19, 2013 4:09 pm | |
| I have the VPD overhead sound bar in mine and you can get two different brackets for them one to mount at angle under the roof behind your head facing forward and another to mount facing down in middle of your roof were your overhead gun rack would go. I have both brackets because in the summer I take back window out and actually use the sound bar where as in the winter I dont so I move it to the middle since I put the back window in and use my rhino more for hunting and less for jamming out. Here is specs of mine and I cut the cig plug off and wired to battery direct so I could jam with key off. I also drilled a hole up in the passenger side front roll bar and place a gromet and ran wire down it and drilled another hole in the bottom of roll bar and pulled wire out and right into battery so no wires ran down the roll bar to get ripped off by limbs. ATV /UTV SIX SPEAKER AMPLIFIED SOUND BAR
- Just plug in 12 volt power plug for instant plug and play
- Powerful 100 Watt amplifier with On/Off switch
- No Radio/Head unit necessary — Just plug in any iPod/MP3 Player
- Separate Docking Station to hold your iPod/MP3 Player
- Docking station sticks anywhere and fits any player, even upside down
- 12 Foot 12 Volt Power Cable with connector
- 12 Foot Auxiliary cord with iPod/MP3 Connector
- Made from tough, rugged, weather resistant Rotational Molded Textured Plastic
- Overhead Map Lights (2)
- Includes Wiring Harness & Instructions
- Easy to install
- Draw Only 4 Amps Max
- (2) 6.0" High Output Woofer
- (2) 2.0" Mid-Range
- (2) 1.0" Super Dome Tweeter
- High Capacity Crossover
- Carbon Fiber Weather Resistant Cones
- Butyl Rubber Surround
- 200 Watt Max High Output Power
- 50 Watt RMS
- 24 oz Strontium Magnet
- Frequency Response: 55 Hz - 20,000 Hz
- Sensitivity: 94.9 dB 1m/1W
Includes (6) pre-wired Mobile Authority Speakers two 6" High Output Woofers, two 2" Mid-Range and two 1" Super Dome Tweeters with a High Capacity Crossover. | |
| | | thePayne
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? Wed Jun 19, 2013 4:17 pm | |
| Also forgot to mention I am super impressed with mine I can't believe the sound that comes out of that thing at WOT I'm still jamming out and I bet it only weights a 1lb its so light that whats impressive. But know for you with 4 of the corner boxes I would imagine that thing would be super loud and you might want to throw on some curb feelers and air brushed naked chick on your hood and call it good. | |
| Subject: Re: VDP SPEAKERS FOR JEEPS & RHINOS...ANYBODY??? | |
