| Diff seal bad | |
+5SteveS KJrhino CUSTOMIZEDRHINO13 WV Hot Rod Rhino Firefighter 9 posters |
| Subject: Diff seal bad Sat Apr 13, 2013 10:03 pm | |
| I guess it would be safe to say I have a rear diff seal out ? Oddly enough, I only had to add very little fluid. Maybe a quarter cup. I did pull the vent line off and blow through it. I think it may have been stopped up. | |
| Subject: Re: Diff seal bad Sat Apr 13, 2013 10:30 pm | |
| i would say..lol..i should have it | |
| Subject: Re: Diff seal bad Sat Apr 13, 2013 10:33 pm | |
| How many miles you got on your bike now firefighter? | |
| Subject: Re: Diff seal bad Sat Apr 13, 2013 11:08 pm | |
| - CustomizedRhino13 wrote:
- How many miles you got on your bike now firefighter?
3800 miles ! I've slowed down a bit . HAHA | |
| Subject: Re: Diff seal bad Sat Apr 13, 2013 11:09 pm | |
| - WV Hot Rod Rhino wrote:
- i would say..lol..i should have it
How bad is it to change out ? | |
| Subject: Re: Diff seal bad Sat Apr 13, 2013 11:27 pm | |
| ugh maybe awful.. maybe easy.. shouldn't be a problem for a knowledgeable rhino runner and some helpful advice from the HRRF when i bought mine it only takes a half a quart or so to drain/refill. | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 4:56 pm | |
| How does the rear drive shaft come out ? | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 5:03 pm | |
| Hold on now, you sure that isn't just brake pad grease? They slather that stuff on to keep the brake rotor from rusting. | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 5:13 pm | |
| As fast as I am going through rear brake pads, I should just leave it. We could call it an oiler mod !! HAHA | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 5:28 pm | |
| When you pull the rear diff back, after you unbolt it, the drive shaft slides out. There's a little button inside the drive shaft that slides out usually. It's plastic. Make sure you grab it. Nut inside where the drive shaft slides together. Unscrew and pull off and pop seal out. I'd change them all. Cause usually when you change one, the others leak about a week later. | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 5:42 pm | |
| thanks banchee6 ! That will hep a bunch ! | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 9:46 pm | |
| let us know how it goes firefighter.. | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 10:41 pm | |
| Glad You asked ! HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Like to never got the drive shaft out. Then the nut holding the couple on was barely finger tight. Then I found a washer of some sort just laying in it !!!! | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 10:50 pm | |
| that washer is broke...the rest is in the end of the shaft...i have them | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 10:52 pm | |
| SEND IT !!!!!!!!!!! Please !!! | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 11:03 pm | |
| Subject: Re: Diff seal bad Mon Apr 15, 2013 11:11 pm | |
- boxed and ready..
Ask Nikki how much I owe ! | |
| Subject: Re: Diff seal bad Wed Apr 17, 2013 12:53 am | |
| Holy cow did you notice anything else besides the leak? id like to avoid that,... | |
| Subject: Re: Diff seal bad Wed Apr 17, 2013 12:59 am | |
| Subject: Re: Diff seal bad Wed Apr 17, 2013 1:09 am | |
| dang i will keep an eye on mine thanks, | |
| Subject: Re: Diff seal bad Fri Apr 19, 2013 1:13 pm | |
| Well crap ! Guess what I found while I have it all tore down. This is not mine, but is identical. Pic found on southernsxsriders.com. Apparently this is a very common problem. Good thing is, the guy who's pic I used, had a very strong repair that I think I can do. | |
| Subject: Re: Diff seal bad Fri Apr 19, 2013 1:42 pm | |
| looks like time to fire up the welder, happened to a buddy of mines 04 | |
| Subject: Re: Diff seal bad Fri Apr 19, 2013 7:56 pm | |
| I've been reading about adding the extra diff support might want to check it out while you in there , suppose to stop your problem from happing again | |
| Subject: Re: Diff seal bad Fri Apr 19, 2013 8:11 pm | |
| Didn't know stock rhinos had this problem. | |
| Subject: Re: Diff seal bad Fri Apr 19, 2013 8:38 pm | |
| Add a rear diff support while your fixing it.the upper bolts work their way loose and end up cracking the stock supports,good to keep a check on when u are doing maintenance on it.good thing u found it before it messed up your diff!! | |
| Subject: Re: Diff seal bad | |
| Diff seal bad | |
