| HELP for grinding a weld | |
+6madmax 1 rhino727 onebuilder KJrhino WV Hot Rod Rhino Firefighter 10 posters |
| Subject: HELP for grinding a weld Tue Apr 16, 2013 11:16 pm | |
| Guys I need any pointers You have for grinding a weld down inside my exhaust pipe. I'm using a dremel tool and I have a couple different wheels. Looking for advice on what to use ! Or is this just going to take forever !!! | |
| Subject: Re: HELP for grinding a weld Tue Apr 16, 2013 11:30 pm | |
| metal bur bit in a die grinder | |
| Subject: Re: HELP for grinding a weld Tue Apr 16, 2013 11:40 pm | |
| X2 they work awesome just be careful they can remove a lot if your not careful | |
| Subject: Re: HELP for grinding a weld Tue Apr 16, 2013 11:48 pm | |
| You guys are my Hero's !!! I have actually used those before, just forgot about them ! Thanks a bunch !
On my exhaust welds, should I go completely flat or leave a little and round them off ? | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 12:50 am | |
| Completely flat would flow better Id be worried about it breaking at the welds if you went too much maybe james or someone will chime in but i might just take some off and round it to be safe.. i never had stock exhaust so not sure how much id take. my .02 | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 10:09 am | |
| Yea, I'm thinking I better leave a little for strength | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 10:46 am | |
| weld it on the outside then it cant break...i think thats what i did when i ran a slip on in 09 | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 10:49 am | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 11:25 am | |
| - KJrhino wrote:
- Completely flat would flow better Id be worried about it breaking at the welds if you went too much maybe james or someone will chime in but i might just take some off and round it to be safe.. i never had stock exhaust so not sure how much id take. my .02
I went flush, being very careful not to take any material away from the tubing, just bead material. | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 12:57 pm | |
| rotary file in die grinder, X2 on the outside weld, on the next weld if you leave a small crack for your weld to penetrate you should have very little clean up on the inside an a stronger weld also a flapper disc on a small 4" grinder does great on clean up where it will reach | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 6:50 pm | |
| x2 small bead on the outside did you take any pics of the weld in the heaser tube | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 7:06 pm | |
| let us know how it works out i my try it this weekend, do you need new gaskets as well? | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 7:37 pm | |
| I had an order sitting at JBS waiting to ship, so I just had Him add donuts gaskets to it. After I got it out tho, I didn't need them. I'm still waiting on diff seal, so It will be a little bit before I put it back together. | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 7:38 pm | |
| cool maybe i should order some to be safe? | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 7:40 pm | |
| Most people say You will not need them, But I didn't want to get it tore down and then need them. | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 8:27 pm | |
| cool if need be my local yamaha deal might have them in stock | |
| Subject: Re: HELP for grinding a weld Wed Apr 17, 2013 9:29 pm | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 6:51 pm | |
| looks good gona rain fri think i'm gona give it a try since im only working 4 12's now thanks to omamas coal hatin | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 6:59 pm | |
| Can't wait to fire mine up and see how much difference it makes. Was very surprised at how big the weld was.
I did not not grind mine completely flat. I left just a little hump, then rounded it off and polished. | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 8:19 pm | |
| sounds good let us know when your up and runnin | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 8:31 pm | |
| Are you going to rejet Firefighter? | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 8:49 pm | |
| i wouldn't think you would need to | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 8:50 pm | |
| also did you weld around the outside of the flange or leave it alone | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 9:01 pm | |
| That's what I want to hear! | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 9:02 pm | |
| The part that's like a little coupling, I welded it all up because mine was backfiring, no problems since! | |
| Subject: Re: HELP for grinding a weld | |
