In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 Bot
Temperature & Carb tuning?? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Temperature & Carb tuning?? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Temperature & Carb tuning?? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Temperature & Carb tuning?? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Temperature & Carb tuning?? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Temperature & Carb tuning?? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Temperature & Carb tuning?? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Temperature & Carb tuning?? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Temperature & Carb tuning?? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Temperature & Carb tuning?? Vote_lcapTemperature & Carb tuning?? Voting_barTemperature & Carb tuning?? Vote_rcap
3 posters
Temperature & Carb tuning?? Empty
PostSubject: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeThu Apr 18, 2013 9:45 pm
How much does temperature effect tuning on a carb? Pretty chill here today(25*) and my a/f reading are off from last weekend(50*) before it got cold again. Like a Star @ heaven
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeThu Apr 18, 2013 10:41 pm
the colder the temp requires a richer mix , warmer leaner
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 12:00 am
x2 cold air is more dense
more air = more fuel
did you get your turbulator yet, or are you still packed in with the snow?
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 12:59 am
Yep, got the turb tonight, and yep the snow is deep and wet. The ground is warm so it is shrinking and should have open streets by mid-weekend for the final carb tuning with the turbulator installed. Like a Star @ heaven
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 8:39 am
ok guys whats a turbulator a turbo? Question
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 9:59 am
Temperature & Carb tuning?? RhinoTurbulator003_zpsa26e7866
Denny, This end will butt up to the carb exhaust(out) side.
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 10:04 am
See thread on "what say you on a/f mixture number". An idea from Denny for a little more kick in the pant for the ole Turd. So though while I playing with the carb I'd give it a try. Like a Star @ heaven
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 10:48 am
in my haste (and a few too many spirits) i forgot that the intake tract on the rhino is different. sorry. if it will fit inside the part below called joint 1 part no. 1 (?!) that would be a better place. i don't think the tract will seal correctly if you place it in the rubber boot, and that would be an even bigger problem.
if the diameter of the ring is smaller than the inside diameter of joint 1, measure the inside diameter of the joint and that should be the correct size. i don't know why they would make the i.d. of the intake tract (joint 1) larger than the throat of the carburetor.
if it doesn't fit, mail it to me and i'll give it to my grandson as a birth control device lol.
[img]Temperature & Carb tuning?? Intake10[/img]
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 11:27 am
Denny, The part #1 diameter size is larger than the flange on the turb, so there is no butting the flange up to the #1 port hole. The turb would just fall into the head. I'm going to call Dennis Kirk today and see if they have one that will fit the Rhino. Like the idea for the G-Kid, never know might be the next best greatest thing to hit the streets. lol....
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 11:33 am
did you measure the i.d. of joint #1?
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 12:09 pm
No, I'm at work right now. But I will. Thanks
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 3:12 pm
The ID on part #1; 1 15/32", and the OD on the turb flange, 1 15/32". The gentlman I talked with at Dennis Kirk's, said you definitely want the turb at the mouth of the head manifold port. Gave her a shot.Cool
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 3:18 pm
that would be a hair over 37 mm. "we're gonna need a bigger boat."
https://www.denniskirk.com/kolpin/turbulator-for-36-38mm-carbs-tu11.p172134.prd/172134.sku
PostSubject: Re: Temperature & Carb tuning??   Temperature & Carb tuning?? Icon_minitimeFri Apr 19, 2013 8:44 pm
[url=https://www.denniskirk.com/kolpin/turbulator-for-36-38mm-carbs-tu11.p172134.prd/172134.sku
https://www.denniskirk.com/kolpin/turbulator-for-36-38mm-carbs-tu11.p172134.prd/172134.sku[/url][/quote]
Got the 36-38mm coming as soon as they receive the 30-34mm. Very excellent customer service at Dennis Kirk. They'll cover shipping cost for the replacement piece. This should give me time to get use to the feel of the other mods before implementing the turbulator. Laughing
