| The Underdawg! | |
+20thekevin Tunderslimer Guenther flimmy RiverRat EddieMc Rhino Russ Chief1979 T.Rhino bubba53 REDRHINO64 WV Hot Rod Rhino rhino727 madmax 1 Jet CUSTOMIZEDRHINO13 hymarker KJrhino Firefighter UnderDawg 24 posters |
Guenther
| Subject: Re: The Underdawg! Sat Jul 06, 2013 1:27 pm | |
| That's a sweet looking ride. ME likey! | |
UnderDawg
Rhino Russ
Posts : 69 Join date : 2013-04-18 Age : 53 Location : Grantsville Md.
| Subject: Re: The Underdawg! Sun Jul 07, 2013 11:53 am | |
Tunderslimer
| Subject: Re: The Underdawg! Tue Jul 09, 2013 4:34 pm | |
| I'm diggin it. I'd love to lift mine but then it wouldn't fit in my trailer... I've already tried the... "Honey, you know we could lift the rhino if we got a bigger trailer." It's NOT going to happen, so I'm stuck at riding lower than stock haha | |
| Subject: Re: The Underdawg! Tue Jul 09, 2013 7:23 pm | |
| That rhino is looking tough joel......nice work!! | |
| Subject: Re: The Underdawg! Wed Jul 10, 2013 6:12 pm | |
| Did you notice any difference in the way it drives with the lift, does it feel any more top heavy. | |
UnderDawg
| Subject: Re: The Underdawg! Wed Jul 10, 2013 8:45 pm | |
| Kevin, at this time I'm running SRA offset rims on the back with wheel spacers all around so stability is not an issue...but that all could change when I decide on a new wheel combo. | |
chammons
Posts : 14 Join date : 2013-03-10 Age : 43 Location : Fayetteville, AR
| Subject: Re: The Underdawg! Wed Jul 10, 2013 9:23 pm | |
| That looks awesome, good looking ride! | |
| Subject: Re: The Underdawg! Sat Jul 13, 2013 9:37 pm | |
| - UnderDawg wrote:
- I just finished adding tunes today. I have a 200 watt amp in a ammo can under the seat' with a MP3 mounted on the dash and 6.5 bazooka's in 6'' end caps.... this will work for now.
are those pvc pipe end caps ? and how are the speakers attached | |
| Subject: Re: The Underdawg! Sat Jul 13, 2013 10:13 pm | |
| Wow, looks like when you get a plan you get it done ASAP,nice ride | |
UnderDawg
| Subject: Re: The Underdawg! Sat Jul 13, 2013 10:59 pm | |
| - madmax 1 wrote:
- UnderDawg wrote:
- are those pvc pipe end caps ? and how are the speakers attached
Mick, yes they are. I use schedule 40 end caps with 2'' of pipe glued in the ends for the speakers to mount to then I mounted through the headrest mount using a 1/4,2'' bolt. I will hide all my wiring when I do the cage chop.. [UR L=https://s1234.photobucket.com/user/joewolfone/media/20130422_185704.jpg.html] [/URL] | |
UnderDawg
| Subject: Re: The Underdawg! Sun Jul 14, 2013 12:11 am | |
UnderDawg
| Subject: Re: The Underdawg! Sun Jul 14, 2013 12:24 am | |
| I used 6.5 bazooka's. I only wish I'd tried some fiber fill for additional base. | |
| Subject: Re: The Underdawg! Sun Jul 14, 2013 1:02 pm | |
| Subject: Re: The Underdawg! Fri Jul 19, 2013 8:58 am | |
| thanks for the tips will try some fiber fill in mine, went went with a pair of jbl 6.5 3 ways and the Jensen marine head unit now just waiting for the ups man thanks mick | |
| Subject: Re: The Underdawg! Fri Jul 26, 2013 1:26 pm | |
| thanks for the info underdawg got mine hooked up with pipe caps like yours worked out great, mick | |
UnderDawg
| Subject: Re: The Underdawg! Fri Jul 26, 2013 10:10 pm | |
| Cool! would love to see your setup. | |
| Subject: Re: The Underdawg! Fri Jul 26, 2013 10:42 pm | |
| thanks will post afew pics when we get back from Gettysburg sun | |
UnderDawg
| Subject: Re: The Underdawg! Sun Aug 18, 2013 1:28 pm | |
| I finally decided on a top and added some much needed doors. hopefully they will help keep the mud out my preferred drink of choice. Today I'm working on some more light. I still need to add a fuse block and placement of switches. I plan on shitcanning the Halogens and replacing them with LED's such as these. | |
| Subject: Re: The Underdawg! Sun Aug 18, 2013 2:51 pm | |
| A single row 40" Will be a little cheaper and about as bright. Maybe just a few hundred lumen less and easier to wire with a wiring harness. All plug and play
| Subject: Re: The Underdawg! Sun Aug 18, 2013 6:55 pm | |
| Subject: Re: The Underdawg! Sun Aug 18, 2013 11:11 pm | |
| Great looking Rhino Joel, I like the LED's to replace your halogens, because they are less conspicuous, take up less room and less power. The top and doors are a great addition. | |
UnderDawg
| Subject: Re: The Underdawg! Sun Aug 25, 2013 1:26 pm | |
| your gonna love it | |
| Subject: Re: The Underdawg! | |
| The Underdawg! | |
