In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests :: 2 Bots
Fuse Block with Relay Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Fuse Block with Relay Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Fuse Block with Relay Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Fuse Block with Relay Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Fuse Block with Relay Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Fuse Block with Relay Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Fuse Block with Relay Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Fuse Block with Relay Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Fuse Block with Relay Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Fuse Block with Relay Vote_lcapFuse Block with Relay Voting_barFuse Block with Relay Vote_rcap
lost|concept
6 posters
lost|concept
Fuse Block with Relay Empty
PostSubject: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 6:32 pm
I see these fuse blocks with relays advertised everywhere for rhino accessories. Are these things worth it and are they needed even?
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 7:26 pm
I liked the wright up Chris did on the accessory wiring an yes I think the fuse block is the way to go , been looking into marine ones to do mine
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 8:04 pm
Here is what I'm using and have no issues in 7 years.
http://www.painlessperformance.com/webcatalog/largeview.php?SearchField=70207
lost|concept
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 8:10 pm
So do you recommend the use of a second battery as well? Or not needed unless pulling major amps?
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 8:15 pm
What is your amp draw? If your running a stereo and amp and a bunch of lights ,yes. If not that much of a draw no. It just depends on your power needs.
I'm only running a single battery, it's an Odyssey PC 925.
lost|concept
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 8:16 pm
Where can I find this write up?
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSun Apr 28, 2013 9:02 pm
look up( putting in gauges) under lighting , stereo , and electrical Chris talks about the fuse block
lost|concept
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeTue Apr 30, 2013 11:56 pm
Thanks for the info. Ordered one on Sunday. Should be in tomorrow morning...
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeSat May 04, 2013 3:30 am
cool tell how it turns out
soarkrebel
soarkrebel
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeMon May 13, 2013 2:26 pm
I am looking at the painless or something like it to add some things. It's the smart way to go.
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeTue May 14, 2013 12:46 pm
check out the blue sea marine fuse blocks seem nice at less than half the price of the painless if your interested I know painless makes great stuff though
brianak
PostSubject: Re: Fuse Block with Relay   Fuse Block with Relay Icon_minitimeTue May 14, 2013 2:05 pm
That's the one I used. Just have to wire in a relay.
» Painless fuse block
» Painless Fuse Block Install
