| Does your Rhino drag? | |
+4123.bert0621 Chief1979 WV Hot Rod Rhino chuddly 8 posters |
| Subject: Does your Rhino drag? Thu May 09, 2013 8:58 am | |
| My rhino does not seem to roll very well. I dont know if its a Rhino thing in general or if its a hanging part or whats going on. I know its not the rear caliper (drove it around and then felt the rear rotor and it wasnt hot) hanging up but i didnt get to check the fronts. It also doesnt take off real quickly when you press the gas (doesnt move for as soon as the RPM increases it kind of hesitates). I dont know if the not taking off thing is the wet clutch or if it is more with something hanging up...just curious. Thanks in advance. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 9:02 am | |
| use yamaha oil only..may be the wet clutch...or a wheelbearing..jack it up and let us know | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 9:42 am | |
| Will do ....thanks for the reminder on the wheel bearing. I dont know about the oil the previous owner used. I would hate to guess because it wasnt very well maintained before i got it. Sucks also that wet clutches are so stinkin expensive. | |
Chief1979
Posts : 91 Join date : 2013-04-09 Age : 42 Location : Cookeville, TN
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 9:47 am | |
| I know that my rhino is kinda hard to push around when its not running and the trans. is in neutral, parking brake off. Haven't tried doing it with the engine running. I know my brakes aren't hanging up, and the wheel bearings are tight. I was wondering the same thing.
I use Valvoline 15w40 HD oil just for reference. | |
Chief1979
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 9:55 am | |
| Mine does takeoff quickly when getting into the gas. It has a slight stall, but pulls great. And when in low range, it crawls well. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 10:52 am | |
| i would check it if it has any stall | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 10:58 am | |
| - WV Hot Rod Rhino wrote:
- i would check it if it has any stall
How would i go about doing that? | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:15 am | |
| Mine is hard to push in neutral also, normal maybe. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 12:00 pm | |
How would i go about doing that? you will need a gasket to look at it | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 12:49 pm | |
| It should not be hard to move in neutral. I can roll mine around on the trailer with one hand on a tire when I load it before I set the brake. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 12:59 pm | |
How would i go about doing that? you will need a gasket to look at it Ok...but where do i look? | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 3:46 pm | |
| A lot has to do with your tires. My Rhino on Bighorns is a one hand push anywhere on hard pack or cement. On Outlaws, it's all I can do just to push it in neutral on level cement. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 3:49 pm | |
| I didn't take that in to consideration, I guess I just figured everyone had Big Horn's | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 3:58 pm | |
| im on factory tires...I dont think its a tire thing...feels like more mechanical.
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 6:02 pm | |
| When my tires are @14 psi on concrete not bad,10psi on dirt its hard to push. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 6:10 pm | |
| I own a body shop guys....I know a mechanical drag when I feel it...its not tires. Just asking what the usual culprits are is all and where to look | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:09 pm | |
| Jack that dude up then and go wheel to wheel and see where the resistance is. Hopefully it's isolated to just one wheel. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:29 pm | |
| I believe James is referring to a gasket as pulling the wet clutch out to inspect it but jack it up and spin and shake first simple quick things first.. mine is pretty easy to pull/push with my mudlites sitting and not running | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:47 pm | |
How would i go about doing that? you will need a gasket to look at it Ok...but where do i look? To get to the wet clutch, pull the Hotrod sheave off, then the fixed sheave behind it, then there is a cover (that is where there is a gasket),. behind that cover is Your wet clutch. | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:48 pm | |
| Subject: Re: Does your Rhino drag? Thu May 09, 2013 11:54 pm | |
| Subject: Re: Does your Rhino drag? Sun May 12, 2013 3:39 pm | |
| Did you ever find out what it was? | |
| Subject: Re: Does your Rhino drag? Sun May 12, 2013 8:26 pm | |
| havnt had time....I hope to look at it this week. Maybe Wednesday???? I wanted to add its nothing horrible because I was able to clock my self with GPS at 52mph yesterday. | |
| Subject: Re: Does your Rhino drag? Fri May 17, 2013 11:36 pm | |
| Just installed my new JBS HOTROD sheave,set tires at 10PSI and now it rolls free and easy. | |
| Subject: Re: Does your Rhino drag? | |
