| How To Check Your Rhino 700 TPS | |
+13NickH RiverRat ASPENDELLROVER thePayne brianak Stuntmanmike Bayou Tiger 123.bert0621 banchee6 scottwv WV Hot Rod Rhino Dizzledog1 Mrs. Hot Rod 17 posters |
Mrs. Hot Rod Admin
| Subject: How To Check Your Rhino 700 TPS Thu May 09, 2013 10:51 am | |
Dizzledog1
| Subject: Re: How To Check Your Rhino 700 TPS Thu May 09, 2013 11:50 am | |
| If its not between those numbers what do ya do? Replace? Adjust? | |
| Subject: Re: How To Check Your Rhino 700 TPS Thu May 09, 2013 11:56 am | |
| adjust tps while the gauge is on...might have to adjust the throttle cable play to get full range | |
| Subject: Re: How To Check Your Rhino 700 TPS Thu May 09, 2013 10:57 pm | |
| adjust your tps...that just sounds soooo dirty !!... | |
| Subject: Re: How To Check Your Rhino 700 TPS Fri May 10, 2013 3:30 pm | |
| mine is 17 and 92,,,, what i have to adjust | |
| Subject: Re: How To Check Your Rhino 700 TPS Sat May 11, 2013 10:42 pm | |
| Great tip, I will check mine ASAP. | |
Bayou Tiger
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 11:35 am | |
| Checked mine and was at 16 and 85. Adjusted the throttle cable and was able to get 18 and 95. Couldn't get passed 95 on upper. Is there anything more to do other than adjusting the cable? | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 12:19 pm | |
| - banchee6 wrote:
- mine is 17 and 92,,,, what i have to adjust
adjust cable slack...just a little to much slack...not much though | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 12:21 pm | |
| - BayouTiger wrote:
- Checked mine and was at 16 and 85. Adjusted the throttle cable and was able to get 18 and 95. Couldn't get passed 95 on upper. Is there anything more to do other than adjusting the cable?
that thing is gonna run alot better...adjust the tps to 18 on the bottom or adjust it a little more on the cable | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 12:42 pm | |
| Good Right up James, Now when someone doesnt get the MPH they thought they should have, This is a good starting point after checking the clutch. | |
Bayou Tiger
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 2:32 pm | |
| - WV Hot Rod Rhino wrote:
that thing is gonna run alot better...adjust the tps to 18 on the bottom or adjust it a little more on the cable All I did was adjust the cable to get 18 and 95. How else do you adjust the tps? | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 4:25 pm | |
| They come with only so much adjustment, your only other option is to replace it. | |
brianak
Posts : 58 Join date : 2013-03-26 Location : Anchorage, AK
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 8:34 pm | |
| Mine goes from 17 to 83. Where is the throttle adjustment made? | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 8:36 pm | |
that thing is gonna run alot better...adjust the tps to 18 on the bottom or adjust it a little more on the cable All I did was adjust the cable to get 18 and 95. How else do you adjust the tps? i would say you need a little more on the cable..not very much though....i have 1 more vid im making on this too...it has to do with the gas pedal...gonna through all my little secrets out there...lol | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 8:37 pm | |
| - brianak wrote:
- Mine goes from 17 to 83. Where is the throttle adjustment made?
on the cable next to the throttle body | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 8:41 pm | |
wow!!! almost 20% loss............i thought this would help alot...i check all of this before i test... | |
brianak
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:04 pm | |
| Have it up to 96 now. Feels a bit better. Will break the rear tires loose now. You could see a bunch of play in the cable on the top of the gas pedal where the cable connects. | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:05 pm | |
brianak
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:11 pm | |
| Any chance this is the same on the grizzly 700? | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:12 pm | |
brianak
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:23 pm | |
| On a Grizzly you hold the top two buttons to get in diag mode. Then again to get the TPS numbers. Mine were 17-99. Much better than the rhino. | |
| Subject: Re: How To Check Your Rhino 700 TPS Sun May 12, 2013 9:27 pm | |
| - brianak wrote:
- On a Grizzly you hold the top two buttons to get in diag mode. Then again to get the TPS numbers. Mine were 17-99. Much better than the rhino.
nice!! | |
| Subject: Re: How To Check Your Rhino 700 TPS Tue Jul 02, 2013 5:37 pm | |
| Yeah great information thanks James and Nikki I checked my 2012 Rhino and mine was at 17 and 80 probably for the last year that I have owned it and now I adjusted to where its at 17 and 97 and its a whole different animal big difference in feeling in 80 vs 97!! | |
| Subject: Re: How To Check Your Rhino 700 TPS Tue Jul 02, 2013 5:49 pm | |
| so u can only check it if you have an a/f guage? | |
| Subject: Re: How To Check Your Rhino 700 TPS Tue Jul 02, 2013 5:54 pm | |
| - ASPENDELL ROVER wrote:
- so u can only check it if you have an a/f guage?
NO watch the video at the top Nikki posted that shows you how to check the TPS numbers and then to adjust the cable I adjusted mine at the motor after removing the center motor cover where the throttle cable goes into the motor while depressing the pedal till I got the number I wanted and then tighted the nuts back up and checked it again and then checked it again after motor cover was back on to be sure. Now I occasionally check it since I am anal and its so easy to look at. | |
| Subject: Re: How To Check Your Rhino 700 TPS | |
