| How To Check Your Rhino 700 TPS | |
+13NickH RiverRat ASPENDELLROVER thePayne brianak Stuntmanmike Bayou Tiger 123.bert0621 banchee6 scottwv WV Hot Rod Rhino Dizzledog1 Mrs. Hot Rod 17 posters |
| Subject: Re: How To Check Your Rhino 700 TPS Tue Jul 02, 2013 6:02 pm | |
| - ASPENDELL ROVER wrote:
- so u can only check it if you have an a/f guage?
No, you put the dash into diagnostic mode and use the d01 display to read the TPS numbers as you apply thottle. | |
RiverRat
Posts : 171 Join date : 2013-03-12 Age : 44 Location : Tulsa, OK
| Subject: Re: How To Check Your Rhino 700 TPS Sun Jul 07, 2013 1:06 am | |
| I need to check mine and see. Super curious now. | |
NickH
Posts : 83 Join date : 2013-08-21 Age : 51 Location : Northern Cambria, Pa
| Subject: Re: How To Check Your Rhino 700 TPS Fri Sep 06, 2013 8:43 pm | |
| I was searching for reasons my check engine light came on the other day for no apparent reason and came across this topic. So I checked it out today before work and I was getting 16 & 85. Quick adjustment and up to 95 now. Thanks. No other trouble codes so I still don't know why my engine light was on. May be one of those damn salamanders from last week. Lol. Any idea on what all the other diagnostic codes or numbers are for when you scroll up thru the displays? Thanks again, very helpful post. Nick | |
Stuckeyp
Posts : 15 Join date : 2013-11-04 Age : 78 Location : Collinsville, Ok
| Subject: Re: How To Check Your Rhino 700 TPS Mon Nov 18, 2013 11:03 pm | |
| Wow what you can learn on this forum. I wasn't getting performance on my 2011 700 . Put JBS sheave kit in and was better, but still only 48 mph. Saw this about tps settings, so I checked mine. Wow 17 and 77. Will adjust cable tomorrow. Thanks for all the info guys | |
| Subject: Re: How To Check Your Rhino 700 TPS Tue Nov 19, 2013 12:22 am | |
| yep, JBS likes his boys to go fast | |
Posts : 1464 Join date : 2013-03-18 Age : 65 Location : Western Quebec
| Subject: Re: How To Check Your Rhino 700 TPS Tue Nov 19, 2013 9:30 am | |
| - Stuckeyp wrote:
- Wow what you can learn on this forum. I wasn't getting performance on my 2011 700 . Put JBS sheave kit in and was better, but still only 48 mph. Saw this about tps settings, so I checked mine. Wow 17 and 77. Will adjust cable tomorrow. Thanks for all the info guys
The right CDI and you'll be at 50-53 and now limits in reverse when your in the mud. | |
sugarbear
Posts : 105 Join date : 2013-03-11 Location : slc, utah
| Subject: Re: How To Check Your Rhino 700 TPS Tue Nov 19, 2013 1:36 pm | |
| just checked mine im at 17 and 89 guess i better adjust it. | |
Quadog
Posts : 220 Join date : 2013-03-11 Age : 59 Location : Bear Branch Indiana
sugarbear
| Subject: Re: How To Check Your Rhino 700 TPS Tue Nov 19, 2013 4:22 pm | |
| I just loaded it up to go for a ride and I'll tell ya the throttle response is a lot better. I'll let ya know after the ride how much difference there is. | |
Stuckeyp
| Subject: Re: How To Check Your Rhino 700 TPS Wed Nov 20, 2013 11:47 am | |
| Got tps adjusted to 17-96. Wow step on it and it gets with it, BUT. Top end went to hell. Starts cutting out at low 30's. Let off gas a little and speeds up to 41 or so. Put new plug in with same thing. Maybe time for new CDI if that will solve problem. Really happy with low end response however. | |
| Subject: Re: How To Check Your Rhino 700 TPS Wed Nov 20, 2013 11:53 am | |
| - Stuckeyp wrote:
- Got tps adjusted to 17-96. Wow step on it and it gets with it, BUT. Top end went to hell. Starts cutting out at low 30's. Let off gas a little and speeds up to 41 or so. Put new plug in with same thing. Maybe time for new CDI if that will solve problem. Really happy with low end response however.
you need a cdi...give me a call | |
Low Flyer
Posts : 44 Join date : 2013-11-20 Age : 59 Location : Richmond, KY
| Subject: Re: How To Check Your Rhino 700 TPS Thu Nov 21, 2013 10:54 pm | |
| Mine is 17 and 95. Can it get better, or should I just leave it alone?
Gil | |
| Subject: Re: How To Check Your Rhino 700 TPS | |
