| Over heated | |
| Subject: Over heated Sat Jun 15, 2013 9:58 pm | |
| Me and the family was out taking a ride in the rhino and the water light came on I pulled over rite then to let it cool down while we was waiting I checked the the radiator and it was cool to the touch. We got home after it cooled and I jacked it up and pulled the bleader screw and added about a cup of antifreeze and it started coming out the hole. Any ideas what might be wrong I was thanking maybe thermostat stuck but open to your guys thoughts don't want to get it wrong and mess something up bad. | |
| Subject: Re: Over heated Sat Jun 15, 2013 10:17 pm | |
| hope it ok, made me sweat just readin it | |
| Subject: Re: Over heated Sat Jun 15, 2013 10:36 pm | |
| No more then it is making me. I went out and restarted it and let it run for about 15 min and it never over heated but there has to be something going on for it to get hot. It happen once before about 2 months ago and it was just air in the line if that is it again I just don't know why it would keep getting air in the line. | |
| Subject: Re: Over heated Sat Jun 15, 2013 11:09 pm | |
| Make sure you bleed both top and bottom good. | |
| Subject: Re: Over heated Sat Jun 15, 2013 11:14 pm | |
| How do you bleed the bottom ? | |
| Subject: Re: Over heated Sat Jun 15, 2013 11:21 pm | |
| same as top,,, just let some fluid come out.... any air in the system will cause trouble | |
| Subject: Re: Over heated Sat Jun 15, 2013 11:24 pm | |
| good info there, love this site always learning | |
| Subject: Re: Over heated Sat Jun 15, 2013 11:35 pm | |
| - banchee6 wrote:
- same as top,,, just let some fluid come out.... any air in the system will cause trouble
Sorry I guess I should have asked where do you do that at ?
| Subject: Re: Over heated Sun Jun 16, 2013 12:45 am | |
| water pump has a bleed screw | |
| Subject: Re: Over heated Sun Jun 16, 2013 1:21 am | |
| im sorry, I should have seen or figured that out too.... yes the pump has a bleeder screw as well.... hope that fixes your problem... | |
| Subject: Re: Over heated Sun Jun 16, 2013 1:26 am | |
| We all need a temp guage with a sending unit close to the engine where the thermostat is. I remember when James' water pump broke, his temp was low on the guage, radiator was cool, heater blew cool, and the engine got so hot the thermostat collapsed. Scary stuff. | |
| Subject: Re: Over heated Sun Jun 16, 2013 1:29 pm | |
| Thanks for your help guys I bleed it from the bottom also and it came out with tons of pressure and started it with the the radiator cap off and watched the coolant moving so I guess the water pump is ok and it never over heated so maybe ok what do you guys thank ? | |
| Subject: Re: Over heated Sun Jun 16, 2013 1:36 pm | |
| i would do a pressure test on system and cap and then replace water pump and thermostat | |
| Subject: Re: Over heated Sun Jun 16, 2013 1:46 pm | |
| How do you cheak the cap ? | |
| Subject: Re: Over heated Sun Jun 16, 2013 3:03 pm | |
| take it to JBS.lol..maybe you can use the radiator cap tester when you get there... | |
| Subject: Re: Over heated Sun Jun 16, 2013 3:10 pm | |
| Subject: Re: Over heated Sun Jun 16, 2013 4:06 pm | |
| Yes it is stock and I'm sure it will be there before to long anyways | |
| Subject: Re: Over heated | |
| Over heated | |
