James suggested that I check my flywheel key for the issue I'm having. Do I need to pull the flywheel to check it or can I just pull the cover? I've read the flywheel can be a bitch on these...any suggestions?
James, just tried you...went to voicemail and the mailbox is full. Give me a ring if you get a few minutes 207-838-8014. I'll try again this afternoon.
Thanks
