| gas mileage? | |
+9Hump CUSTOMIZEDRHINO13 varmint10 flimmy 123.bert0621 ChrisH foyota86 WV Hot Rod Rhino 09-rhino700 13 posters |
| Subject: gas mileage? Mon Jul 22, 2013 3:20 pm | |
| so how many miles can you go on a single tank of gas? I went around 40 on a single tank. stock 700. is that normal..? bad? | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 3:21 pm | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 3:25 pm | |
| could my sensor be wrong in the tank? haven't physically looked in the tank just goin off the digital in the dash.. also does the tps go out or just the throttle cable ? | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 3:35 pm | |
| I had 45 miles showing and no bar on fuel gauge(well back and forth from no bar to one). Only put 4.5 gallons in tank when I filled it back up. Manual says it hold 7.93 gallons. Sounds like my fuel gauge is off a little. On the 07's does the fuel bar flash or just don't show nothing when low? | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 3:42 pm | |
| we can go 14 miles after it starts flashing | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 3:54 pm | |
| I get about 40-50 miles out of a tank of fuel. I ride until it starts flashing and then ride a little more because the gauge seems kinda conservative. It seems like there's 1.5 gallons after my fuel gauge starts flashing. But I usually get about 40-50 miles between fill ups. | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 4:02 pm | |
| mine never started flashing so if sounds average.. | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 6:43 pm | |
| When I ride the Rhino hard on the trails it can get about 110-115 km's,ride relaxed and easy like when hunting,200 km to a tank,about 70 miles riding hard and about 120 when ridden slower.15.5 mpg | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 10:49 pm | |
| mine never flashes , oh that's right I don't have a gauge.
I think I've done 80 miles on a tank before down at Hatfield. | |
varmint10
Posts : 82 Join date : 2013-03-15 Location : Northern Calif.
| Subject: Re: gas mileage? Mon Jul 22, 2013 11:22 pm | |
| Wow, I have an 09 700, it has some JBS koolaid but not a big bore. Many of my trips are around 80 miles, probably 50% roads and 50% trails, but I have never had less than a single bar on the guage. Even then when I filled it up it never has taken more than 6 gallons. | |
| Subject: Re: gas mileage? Mon Jul 22, 2013 11:33 pm | |
| hmmmmmmm interesting any ideas why I might be gettin bad mileage? | |
varmint10
| Subject: Re: gas mileage? Mon Jul 22, 2013 11:39 pm | |
| - 09-rhino700 wrote:
- hmmmmmmm interesting any ideas why I might be gettin bad mileage?
I have found several other Rhinos that the E-Brake was hanging up and dragging. I did put a air-fuel gauge on mine and really tweaked the MSD control, but that was for power not mileage. I think since I put the sheave and cam in I have my foot in it more often than before. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 12:17 am | |
| Bad mileage comes with Rhino 16-17 is about you get. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 12:34 am | |
| will I see better milage with the jbs sheave kit? | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 1:20 am | |
| 40 miles used about a half a tank. | |
varmint10
| Subject: Re: gas mileage? Tue Jul 23, 2013 1:58 am | |
- will I see better milage with the jbs sheave kit?
I doubt it !! It becomes much more fun to drive and you get on it more! I did not see any real change in mileage that I noticed until I put the cam and MSD in mine. I for sure don't get as much mileage now but still not bad. The Razrs I ride with are always using their spare gas before we get back. I have added my gas (2 gallons I have under my seat) only one time when we did 100+ miles on a ride. After that ride is when I filled it up with 6 gallons. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 3:46 am | |
| My fuel gauge started to flash and 5.5 gal filled it up 2 miles later. How far I can go depends on how I run it. If I'm on a very rough rocky trail just crawling along and speeds never go over 20, I seem to run forever before the fuel gauge goes down anymore. Running it hard where the trails allow, using 4x4 some, and climbing some long hills at over half throttle for miles, I would think that I would get about 70 or a little more out of a tank. Running the absolute hell out of the 450 I had, it would shut down at 68-74 miles on a tank.
Last time I rode with James we stopped to top off before going on a long ride and we both held just over $14. I think his was capable of using more, but I was holding him up so he wasn't as hard on the throttle as me. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 3:51 am | |
| Hey Vern, next time you get to the lowest level on the gauge, fill it up and see what it will hold. I bet you are no where near empty. If you are running it until it's dry and quiting at 40 miles, there is no way I would ever want to ride with you. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 7:01 am | |
| I was thanking the same thang. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 7:10 am | |
| I got one of these for my rhino and it seems REALLY accurate. it goes from the bottom of the tank all the way to the top so you get a accurate full reading and empty reading. Also they thing i like about it is there is no long arm like most fuel sensors....rides up and down the pole Rhino Fuel Sender | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 7:28 am | |
| It has to read better then the stock one. | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 9:52 am | |
| it shows no bars on the screen but its not flashing, I will put some in tonight and see what it does | |
| Subject: Re: gas mileage? Tue Jul 23, 2013 10:52 am | |
| No more bars mine flashes and I am in ZEC (conservation area)I start sweating its far to gas station and already used 200 km worth of fuel. | |
Mauser69
Posts : 11 Join date : 2013-03-29 Location : Nogal New Mexico
| Subject: Re: gas mileage? Thu Aug 01, 2013 10:52 am | |
| Very interesting thread. I have only had this thing for 8 months or so, and I wondered if my range was normal - bought my 07 Sport used, and it has been modded some, just not sure what all was done beyond the obvious intake and exhaust changes and bigger wheels/tires. It DOES move real good - easily reached about 60 MPH before I choked down the exhaust some to cut the damn noise! Still will hit 50. Have never even pulled the plug to check for color.
Anyway, I use this thing daily, about 1/3 work around the ranch and 2/3 mid-speed run out to the mail box (about 4 miles). "Mid-speed" means anywhere from 30 - 45 MPH, and there are lots of hills in the road. I live above 7,000 feet. I have never seen my fuel gauge flash, but I did push one tank about 20 miles past the last bar and it still only took about 6 gallons to fill. Got about 100 miles on that tank. Seemed low to me, but now I see it is as good or better than what others are reporting. Thanks for the info to compare it against. | |
| Subject: Re: gas mileage? Thu Aug 01, 2013 12:40 pm | |
| my gauge shows no bars but I looked in the tank and I still have at least 4 gallons minimum left... and I hav around 50 miles on this tank so far.... gunna push it. | |
| Subject: Re: gas mileage? | |
| gas mileage? | |
