In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests :: 1 Bot
Help - Secondary Nut Rounded Off Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Help - Secondary Nut Rounded Off Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Help - Secondary Nut Rounded Off Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Help - Secondary Nut Rounded Off Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Help - Secondary Nut Rounded Off Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Help - Secondary Nut Rounded Off Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Help - Secondary Nut Rounded Off Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Help - Secondary Nut Rounded Off Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Help - Secondary Nut Rounded Off Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Help - Secondary Nut Rounded Off Vote_lcapHelp - Secondary Nut Rounded Off Voting_barHelp - Secondary Nut Rounded Off Vote_rcap
6 posters
Help - Secondary Nut Rounded Off Empty
PostSubject: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 1:52 pm
I need some ideas about how to safely remove the nut that holds the secondary sheave and fan on the shaft. I was trying to remove it, and the nut rounded off. Is there any way to remove that 22mm nut?
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 1:56 pm
I used a dremel, it worked great
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 1:58 pm
Can you say more?
I am deathly afraid of damaging that shaft. Isn't that the transmission input shaft? If you fubar those threads, it could be a nightmare.
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:05 pm
I cut within a pussy hair of the threads(I was scared too) and it came right off. it was a pain in the ass but thats what James and I came up with. for some reason it happens alot to the secondary nut. if you do hit the threads you could always use a die to clean it up
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:13 pm
Thanks!
I thought if having a drink to steady my hands and then carefully cutting that biotch off with my dremel. I guess this also means I will need a new nut.
 James, you got one in stock?
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:21 pm
sucks man what where you wanting to switch out now that caused you to be in there in the first place? Just curious....
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:25 pm
I was going to put those anti-friction washers in. I've had them forever and was going in there to inspect and clean things up. I'm also going to mess with my wet clutch. But no dice this time! LoL
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:34 pm
ChrisH wrote:
Thanks!
thats exactly what I did, when my hand got shaky I took a break and had another drink cus that shaft scared me...lol
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:36 pm
I need to figure out this exact measurement. How close is that to the threads?
Maybe I'll go check...
Laughing
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 2:38 pm
i have found that a lot depends on whether or not the carpet matches the drapes bounce
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 3:04 pm
Laughing
you should be relaxed when you start cutting...lol
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 3:10 pm
call me!!
Crusty
Crusty
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 4:47 pm
These work pretty good as well, cheap and wont mess up your threads
http://www.amazon.com/TEKTON-7580-Nut-Splitter-2-Piece/dp/B000NPZ4ZI
Help - Secondary Nut Rounded Off Nut_sp10
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 5:51 pm
Could you grind two of the sides of the nut flat to fit a cresant wrench and get it off instead of having to cut it off? Or maybe grind each flat side of the nut to clean up the corners and drop your socket size buy one?
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 6:39 pm
Thanks for all the replies. I've removed the primary nut numerous times and the secondary nut a hand full of times. There has never been an issue. Oh well.
 I talked to James and he said to try a chisel and heavy hammer. You gotta be careful of those threads. At least this nut is fairly accessible. I have some ideas now on how to remove the stubborn nut.
James has me a new one on the way.
PostSubject: Re: Help - Secondary Nut Rounded Off   Help - Secondary Nut Rounded Off Icon_minitimeMon Sep 09, 2013 6:49 pm
Chris, were you using a 6-point socket or 12-point?
a 6-point would provide a more secure grip
i've rounded off a few myself with 12-points.
» Nut on Secondary
» how to get the secondary sheave out on a 660
» SECONDARY SEALS
» Greasing the secondary
» 660 700 secondary differences
