| Vibration | |
southark
| Subject: Vibration Wed Mar 20, 2013 10:03 am | |
| Hey guys need some help got a 09 700 and it vibrates like hell at a idle and seems to smooth out when you get the Rpms up,but it still vibrates some also while riding but not as bad.but when idling it shakes the dash and the steering wheel pretty bad. | |
| Subject: Re: Vibration Wed Mar 20, 2013 10:10 am | |
| Have you checked your motor mounts, Ive seen quite a few break. | |
southark
| Subject: Re: Vibration Wed Mar 20, 2013 10:54 am | |
| Yes I did I just put the motor back in and when I pull it out I had one broke but I replace it and checked all of the other ones. | |
southark
| Subject: Re: Vibration Wed Mar 20, 2013 3:38 pm | |
| Thanks to James he knew what was wrong with my motor . What the problem is I didn't get the counter balance sprocket dot lined up on the crank sprocket dot so I have got to pull the magneto cover off and line them up. | |
| Subject: Re: Vibration Wed Mar 20, 2013 7:18 pm | |
| is he the rhino guru or what | |
Yotehunter66 Moderator
| Subject: Re: Vibration Wed Mar 20, 2013 7:26 pm | |
| That's why we're here. | |
southark
| Subject: Re: Vibration Wed Mar 20, 2013 9:31 pm | |
| Well guys I thought that was the problem tore into it and checked what we thought it was and that's not to issuse. So if anyone has any other ideas please help me out. Thanks in advance. | |
| Subject: Re: Vibration Wed Mar 20, 2013 9:38 pm | |
southark
| Subject: Re: Vibration Wed Mar 20, 2013 9:47 pm | |
southark
| Subject: Re: Vibration Wed Mar 20, 2013 11:12 pm | |
| I guess I'll just ride it the way it is maybe I'm just looking into it more than it really is. | |
Mrs. Hot Rod Admin
| Subject: Re: Vibration Thu Mar 21, 2013 10:07 am | |
| i would say a bearing then if its more than before this happened | |
southark
| Subject: Re: Vibration Thu Mar 21, 2013 1:23 pm | |
| Ok think we may have the answer to the vibration problem with my rhino Thanks to James well have a update later this evening. | |
southark
| Subject: Re: Vibration Fri Mar 22, 2013 12:45 am | |
| Update on my rhino.Got it fixed Thanks to James .Thank you!This is what happen,I missed one of the spocket line ups and that will make it vibrate like hell with that said it was the small spocket behind the flywheel that I didnt get on the dot,now that I have got it all in line it has no vibration.So lesson well learned line all of the dots up on the spockets. | |
| Subject: Re: Vibration Fri Mar 22, 2013 12:53 am | |
| Subject: Re: Vibration Fri Mar 22, 2013 9:51 am | |
| Another happy rider. Great job James. | |
| Subject: Re: Vibration | |
| Vibration | |
