dognhogs
Posts : 21 Join date : 2013-03-21 Age : 34 Location : Arkansas
| Subject: brakeline ? Sat Mar 30, 2013 12:57 pm | |
| I've got a 09 700 rhino and brakeline that goes to the rear is busted. Is it best to order one from yamaha or can i get one from the parts house. i haven't taken the old one out yet. any ideas how long it is? and what'd be best to do. all tips and advice is appreciated. | |
Yotehunter66 Moderator
| Subject: Re: brakeline ? Sat Mar 30, 2013 4:35 pm | |
| Take the old one off and take it to a local brake shop. Around here they will usually make one up for you. | |
| Subject: Re: brakeline ? Mon Apr 01, 2013 11:29 pm | |
| - dognhogs wrote:
- I've got a 09 700 rhino and brakeline that goes to the rear is busted. Is it best to order one from yamaha or can i get one from the parts house. i haven't taken the old one out yet. any ideas how long it is? and what'd be best to do. all tips and advice is appreciated.
Are you referring to the brake pipe(brake line from the master cylinder to the tee by the rear diff)? If so, order a new OEM, they are only like $20. Easy to replace! Pull the old one out from the front, near the master cylinder. Install the new one from the same location. It took me maybe 20 minutes to change mine when I did the brake conversion. | |
