| Plastic dip | |
+9CUSTOMIZEDRHINO13 T.Rhino WV Hot Rod Rhino madmax 1 Deuces wild Workhorserhino REDRHINO64 Jet foyota86 13 posters |
| Subject: Plastic dip Fri Apr 19, 2013 9:23 pm | |
| I am trying the plastic dip on the other side of bed, sitting in rhino, it's on your back. My bed was already lined, but not that side (cheap stuff I think). I figured for 10 bucks it may help, if it doesn't I will peel off and line x the whole thing. I have almost got all the rattles and squeaks fixed. Spent a week doing so. Yea I am OCD. Anyone else tried? | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 9:25 pm | |
| i line x the bed and the front of the bed that goes toward the cab----noooooooooooooooooooooooooooooooooooo rattles. none---zippo. | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 9:29 pm | |
| Yea, I am thinking that is the way to go also. I will be divorced if I don't quit spending cash on this mo fo... | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 9:33 pm | |
| I went to lowes hardware and got a sheet of the 3/4" blue insulation and cut it to fit that side of the bed,then i took the metal tape and covered the whole piece.alot more quiet!! | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 9:45 pm | |
| Thanks, so far the plastic dip, sounds more like plastic chit. Not worth the 10 bucks or my time putting it on. When you say metal tape, is it black in color, never heard of it or it may be called something else around my parts? | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:06 pm | |
| You can find it in your local hardware store,its used for ductwork,its silver.used in hvac work.like the ductwork for your heat and air. | |
Workhorserhino
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:16 pm | |
| I did the bed 2 yrs ago. Took it off and did both sides. More for rust protection, but did help with noise. Plus I got to drink a lot of beers waiting for that chit to dry. | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:33 pm | |
| More beer drinking...im starting to understand that working on rhinos and drinking beer goes hand n hand!! lol...or jack daniels ...JET!! | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:36 pm | |
| - RENEGADE64 wrote:
- More beer drinking...im starting to understand that working on rhinos and drinking beer goes hand n hand!! lol...or jack daniels ...JET!!
yep----------------yes sir--------------------------------jack please !!!!!!!!!!!!!!! | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:40 pm | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:42 pm | |
| Ive had some good ole apple pie tonight,much better than jack!! lol!! | |
| Subject: Re: Plastic dip Fri Apr 19, 2013 10:43 pm | |
| Wont be long to bedtime!!lol!! | |
Deuces wild
| Subject: Re: Plastic dip Sat Apr 20, 2013 8:20 am | |
| My bed had an annoying squick so I just pulled the two stock rubber mounts on the front of the bed off squick gone. | |
| Subject: Re: Plastic dip Sat Apr 20, 2013 8:50 am | |
| linex in my area said 425.00 to do just inside of bed doesn't this sound high to you guys | |
| Subject: Re: Plastic dip Sat Apr 20, 2013 9:11 am | |
| sounds high to me but i dont know shit..lol | |
| Subject: Re: Plastic dip Sat Apr 20, 2013 10:57 am | |
| - madmax 1 wrote:
- linex in my area said 425.00 to do just inside of bed doesn't this sound high to you guys
http://www.herculiner.com/ this is what i used on my bed,worked great and looks good!! should be able to get it at your local auto store. | |
| Subject: Re: Plastic dip Sat Apr 20, 2013 11:03 am | |
| Does the spray in bed liner add much wheight ? Some one should come up with A composet bed that would solve the wheight issue and noise issue at the same time. | |
| Subject: Re: Plastic dip Sat Apr 20, 2013 12:04 pm | |
| might give hurculiner or raptor a try save the 400 bucks for a light bar ay!!! | |
| Subject: Re: Plastic dip Mon Apr 29, 2013 1:08 am | |
| x2 on light bar | |
Brady660
Posts : 17 Join date : 2013-05-09
| Subject: Re: Plastic dip Sun May 12, 2013 1:40 am | |
| Does anyone know where i can buy the linex so i can do it myself | |
| Subject: Re: Plastic dip Sun May 12, 2013 2:01 am | |
| cant buy it that why you use what you can buy online or at a parts store, at least in Ca | |
watrsmkr
Posts : 24 Join date : 2013-03-10 Age : 66 Location : Ohio
| Subject: Re: Plastic dip Sun May 12, 2013 1:59 pm | |
| Rustoleum makes a spray on bedliner...about 8 bucks a can. Used 2 on mine and it worked great! | |
| Subject: Re: Plastic dip | |
| Plastic dip | |
