| My 09 Rhino | |
+5rhino727 REDRHINO64 madmax 1 WV Hot Rod Rhino Workhorserhino 9 posters |
Workhorserhino
| Subject: My 09 Rhino Sat Apr 20, 2013 8:40 pm | |
| One of the first changes was the winch mount. Factory location was completely useless for me. Started checking on web for ideas. Found Montana Jacks. Very nice set up, but way to expensive. Decided to build my own. Over to tractor supply for parts. This is a pic of the first piece of the puzzle. Welded hitch receiver to original winch mount plate. | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 8:47 pm | |
| 2nd piece of the puzzle. Winch mounting and plow mounting bracket. Receiver adapters welded to receiver. | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 8:53 pm | |
| Winch setting in place. This is what I wanted for cutting firewood. Winch ready and easily used. Winch plate welded to a drop down adjustable hitch. | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 8:58 pm | |
| This is the fancy piece I copied from Montana jack. The winch rotator. Not fancy, but turns winch 90' for plow. | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 9:02 pm | |
| Here is the winch in place for plow . | |
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 9:04 pm | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 9:05 pm | |
| a frontal view of the plow system. | |
Workhorserhino
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 9:14 pm | |
| With plow mounted and hooked up, ready for use. The plow itself mounts in the lower receiver of the winch mount. The winch cable now runs straight to plow. Doesn't touch fairlead, and no more broken cable. Plus it only takes 10 minutes to hook up. I did this because the way the plow hooked from new SUCKED so bad. But about 120 bucks at Tractor Supply and a Sat afternoon, those days are done. | |
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 10:49 pm | |
| nice pics of your ride I have the montanajack mount like you fabed very price but works great , and the rear has a diff brace built into it, you did real nice work | |
| Subject: Re: My 09 Rhino Sat Apr 20, 2013 10:52 pm | |
| Nice rig you got there!!! | |
| Subject: Re: My 09 Rhino Sun Apr 21, 2013 10:57 am | |
| good job on you project looks nice | |
UnderDawg
| Subject: Re: My 09 Rhino Sun Apr 21, 2013 12:32 pm | |
| Looks good!! Are ya setup to run the winch on the back as well? | |
hymarker
| Subject: Re: My 09 Rhino Sun Apr 21, 2013 1:10 pm | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:20 pm | |
| - UnderDawg wrote:
- Looks good!! Are ya setup to run the winch on the back as well?
Sorry I didn't this post till today. The cable came with the winch. I haven't installed it yet. 2 reasons, haven't needed it yet and to lazy to remove winch contactor. It's bolted to glove box on air cleaner side. Didn't want it getting wet, but very hard to get to. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:25 pm | |
| Floor board protection, the really cheap way. Needed to replace rght side floor pan. Wanted to offer some protection but didn't have any money left, sooooo this is what I did. It's not pretty but should do the job. Might get me honorary redneck award or something. Here goes with the pics thing. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:28 pm | |
| Factory floor cracked from snowbank. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:31 pm | |
| Floor removed. Easy job, drill out rivets, remove screws. Do it when its warm though. Factory floorpan flexes better. | |
Workhorserhino
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:42 pm | |
| New floor pan installed. Extra rivets are holding plastic underneath. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:44 pm | |
| Pic of bottom of guard riveted in place. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:55 pm | |
| This part was a bitch. Used a bottle jack, the jack handle itself braced off tierod and propane torch. Heated plate and bent and braced to get rivets in. Started at bootom of curve and worked up. I know it ant pretty but hopefully it will protect the floorpan from getting broken again. If it does get busted though, I'll buy a spool gun for my welder and weld a nice aluminum piece to fit. | |
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 10:59 pm | |
| Question, does anybody hate removing the console to grease the ujoint by the engine? I do, such a pita! What the hell was Yamaha thinking? I rectified the situation after I was done with the floor pan. See pics. | |
Workhorserhino
Workhorserhino
| Subject: Re: My 09 Rhino Fri Apr 26, 2013 11:16 pm | |
| Here are both pieces back in place and screwed down. A little more trimming will be needed when I get a piece of weatherstrip to fill in gap. Good to go for now. Got 7k on original ujoints so far, trying to get 10k before replacing. Greasing them regularuly and that fnnn console just pissed me off trying to get out. | |
hymarker
| Subject: Re: My 09 Rhino Sat Apr 27, 2013 1:30 am | |
| Hey workhorse, how you like those ultracross tires? How are they in the snow? | |
| Subject: Re: My 09 Rhino | |
| My 09 Rhino | |
