In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests :: 2 Bots
oil change Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
oil change Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
oil change Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
oil change Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
oil change Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
oil change Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
oil change Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
oil change Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
oil change Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
oil change Vote_lcapoil change Voting_baroil change Vote_rcap
 oil change
soarkrebel
txgrown1404
8 posters
txgrown1404
txgrown1404
oil change Empty
PostSubject: oil change   oil change Icon_minitimeSat May 04, 2013 5:46 pm
how much oil do you put back in after changing oil and filter?????? 2.11 qt. or 2.96 qt
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSat May 04, 2013 7:35 pm
Depends on how you change the oil. If you just pull the plug and filter it should be 2.2 qt. If you drain the oil cooler it will be just under 3 qt.
txgrown1404
txgrown1404
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSat May 04, 2013 7:46 pm
how do you drain the oil cooler
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSun May 05, 2013 12:38 am
HMM when i did mine it was 3 qts with filter but i had the wet clutch out just before I serviced it.
Yamalube 10-40 and OE filter is what I used JBS recommended
txgrown1404
txgrown1404
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSun May 05, 2013 11:08 am
yeah i got a yamaha oil change kit it came with 3 qts filter and a few gaskets and a metal lock ring which i guess it was for the oil plug. but im still not sure how much to put in i put in 2 1/2 qts for know gonna go ride this afternnon and see what it does and chrck it then
soarkrebel
soarkrebel
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSun May 05, 2013 11:39 am
Just a little over two quarts ...run it ....kill it....check it again in a few minutes and add accordingly.
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeMon May 06, 2013 5:25 pm
I put 2 + an check then add till its full on stick
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeMon May 06, 2013 6:44 pm
amsoil 4 stroke and add till full on the stick , start and then recheck
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeMon May 06, 2013 7:28 pm
Remove the oil cooler. I'm sure you could blow it out somehow but I remove mine and clean it when I change the oil.
The author of this message was banned from the forum - See the message
oil change Empty
PostSubject: Re: oil change   oil change Icon_minitimeSat May 18, 2013 10:01 pm
Oil and filter change every year,10w-40 Yamalube synthetic,if you want to clean the cooler,remove it, run brake cleaner and air through it.
oil change Empty
oil change
» secondary spring change
» name change
» cam change
» time for a change.
» How to Change the Digi Dash from KPH to MPH
