Okay I have a set of ITP wheels and all four have the 5+2 offset on them.
I have a 2012 700 that is stock except for the wheels. I am currently running mudlites 26x10x12s in the front and 26x12x12s in the rear. I hate how far the rears stick out and how bad the mudlites wear. I think I have decided to go with the same width tire on all 4. My question is if I run the same size tires on all four with the 5+2 offset how will they sit on the machine? Will the rears still be a bit wider, will the fronts then be wider, or will they stick out evenly? I have read way too many posts trying to figure this out and I cannot seem to grasp it.
I am still undecided if I want to go with 9s all the way around or 10s. I do a lot of soft ground riding so I feel like I need the extra width.
Any advice/tips/helps appreciated. Thanks in advance.
Joe
