| Needing advice on wheel offset | |
+5ASPENDELLROVER thekevin chalkminer REDRHINO64 T.Rhino 9 posters |
| Subject: Needing advice on wheel offset Tue Jul 09, 2013 2:06 pm | |
| Ok so I don't understand the hole wheel offset thang and I am looking for someone to explain it to me. I have been looking at knew wheels and tires and I'm pretty sure I am going to go with 26x9 all the way around and was looking for the best wheel offset for this set up I've seen the 2/5 & the 5/2 and the 4/3 but don't know wich would be best or do I understand what it means to be truthful about it I guess I have a Idea but would like some help from you guys before I make a purchase also keep in mind I would like to go with a mid-travel when the money is rite. Thanks for the help. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 2:31 pm | |
| Dang...u must be rolling in the money,new tires and wheels,mid travel,jbs built 787...........sounds like I need a new job!!! lol | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 2:36 pm | |
| No can't do it all at once going to do it on stages. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 3:27 pm | |
| Yea,ive been doing mine in stages for 5 years,now ive made full circle....time for new tires again...lol!! | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 3:36 pm | |
| I know the feeling I will probably need knew tires again before I can afford the mid-travel just trying to not have to buy something twice. When I bought my rhino 3 years ago it came with 14 inch rims and they are beat all to hell and the tires I have on there now won't make to this fall so I was just trying to keep from buying a nother set of 14' tires to go on them if I don't it will end up in never ending circle of me buying 14's so I was just trying to get off that path & look in the future a little I guess. | |
chalkminer
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 3:51 pm | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 4:08 pm | |
| - T.Rhino wrote:
- I know the feeling I will probably need knew tires again before I can afford the mid-travel just trying to not have to buy something twice. When I bought my rhino 3 years ago it came with 14 inch rims and they are beat all to hell and the tires I have on there now won't make to this fall so I was just trying to keep from buying a nother set of 14' tires to go on them if I don't it will end up in never ending circle of me buying 14's so I was just trying to get off that path & look in the future a little I guess.
10-4......I KNOW WHAT U MEAN!...Good luck on your next purchase | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:39 pm | |
| Are you going to stick with 14's | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:41 pm | |
| No wanting to go with 12's | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:43 pm | |
| Im curious to see how much more body roll you get with 26/12's versus the 26/14. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:48 pm | |
| I guess that's a possibility also but the tires I am looking at are supposed be small to size so truly a 25 and hopefully a little stiffer sidewall will help. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:51 pm | |
| my first step would be to pick out my +3 kit and call the maker and see what off set they would run with their kit. I know some kits wont run a stock rim, so might as well get the whole set up matched as well as possible. oh and makes sure you get some carpet to put her on cus after all the money you spend, she deserves a nice home..lol | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:53 pm | |
| lol...if you don't have $30k in your rhino you might as well just get rid of it and get a golf cart. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:55 pm | |
| i can only buy so many flowers to plant in my yard...lol | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 5:56 pm | |
| - ASPENDELL ROVER wrote:
- my first step would be to pick out my +3 kit and call the maker and see what off set they would run with their kit. I know some kits wont run a stock rim, so might as well get the whole set up matched as well as possible. oh and makes sure you get some carpet to put her on cus after all the money you spend, she deserves a nice home..lol
ohh your one to talk. Big money | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 6:24 pm | |
| man I do more research than you think...MR.CC | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 6:44 pm | |
| Ohh I do to that's what I'm doing now and trust me ask my wife it wears her out I won't buy anything until I have researched to no end. But I will have to say you have good taste. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 6:58 pm | |
| thx bro, even if I were rich, I would still do research. my wifee says buy it already, tired of hearing about it. so I say you wanna hear about all the porn I watch.. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 7:06 pm | |
| That's funny shit but I would do the same I thank research is part of the fun. But this one is whipping me I don't know much about this offset rim thang at all. | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 7:12 pm | |
| 5+1 in the front and 4+3 in the rear is stock offset | |
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 8:39 pm | |
| Porn is just research too. | |
TBOMB
| Subject: Re: Needing advice on wheel offset Tue Jul 09, 2013 9:17 pm | |
| Subject: Re: Needing advice on wheel offset Wed Jul 10, 2013 7:02 am | |
| Yes it does some still got a little more figuring to do though thanks. | |
Guenther
| Subject: Re: Needing advice on wheel offset Wed Jul 10, 2013 10:46 am | |
Guenther
| - thekevin wrote:
- Porn is just research too.
It most assuredly is, just don't tell the wife. | |
| Subject: Re: Needing advice on wheel offset | |
