In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests :: 1 Bot
what do your tires look like with 0 air in them? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
what do your tires look like with 0 air in them? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
what do your tires look like with 0 air in them? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
what do your tires look like with 0 air in them? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
what do your tires look like with 0 air in them? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
what do your tires look like with 0 air in them? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
what do your tires look like with 0 air in them? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
what do your tires look like with 0 air in them? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
what do your tires look like with 0 air in them? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
what do your tires look like with 0 air in them? Vote_lcapwhat do your tires look like with 0 air in them? Voting_barwhat do your tires look like with 0 air in them? Vote_rcap
4 posters
what do your tires look like with 0 air in them? Empty
PostSubject: what do your tires look like with 0 air in them?   what do your tires look like with 0 air in them? Icon_minitimeWed May 08, 2013 4:54 pm
i am in the market for new tires. my current tires are titan 589m/t`s they have been awsome tires a bit on the heavy side but have been great. i may stay with that tire cause its been soo good to me but im also wanting a change. the biggest thing for me is i want a tire i can run with 0 air. my titans i can run with 0 air in em without any problems. they support the full weight of the rhino with 0 air. do the maxxis og bighorns support the weight? is there any other tire that can run flat?
PostSubject: Re: what do your tires look like with 0 air in them?   what do your tires look like with 0 air in them? Icon_minitimeWed May 08, 2013 6:55 pm
I don't think a Bighorn is what you want for a run-flat tire. Mine with 0PSI is flat! On the other hand, my Radial Outlaws could be run with no air pressure. Similarly, a set of Outlaw2 (not the OG Outlaws) seems to hold the weight of a SxS with little to no air pressure. This isn't to say that the Outlaws wouldn't roll a bead being run like that, but I know I have run my Radial Outlaws with 0PSI for a few miles. I just didn't make any corners hard and fast.
Those are heavy tires, heavier than your 589s. I'm not sure what tire you might consider that meets your criteria.
Snorhino
Snorhino
PostSubject: Re: what do your tires look like with 0 air in them?   what do your tires look like with 0 air in them? Icon_minitimeWed May 08, 2013 10:06 pm
The Terra cross stay up with 0 air pressure
PostSubject: Re: what do your tires look like with 0 air in them?   what do your tires look like with 0 air in them? Icon_minitimeThu May 09, 2013 12:43 pm
so much for that. i was really wanting to give the bighorns a try. the search continues. outlaws are too aggresive for me. i do ride in mud but nothing hardcore or thick. most of my riding is rocky trail and loose coal silt i need a good all around tire with run flat capabilities.
Workhorserhino
Workhorserhino
PostSubject: Re: what do your tires look like with 0 air in them?   what do your tires look like with 0 air in them? Icon_minitimeThu May 09, 2013 9:52 pm
Hey Mike, you might consider a bajacross tire. I bought a set a few years ago to upstate with a couple buddys. Same thing rocks and coal dirt, not much mud. They are tough tires, and run flat. You cant go full speed, but they will get you back. They are heavy though. Used them this winter in the little bit of snow we got and did better than I thought. Got me up the hill to cut and split wood. Overall I'm happy with them.
» Anyone tried these tires?
» New tires
» who is running 30" tires?
» Tractor tires?
» spare tires
