In total there are 51 users online :: 0 Registered, 0 Hidden and 51 Guests :: 2 Bots
Clutching i need help!!!! Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Clutching i need help!!!! Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Clutching i need help!!!! Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Clutching i need help!!!! Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Clutching i need help!!!! Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Clutching i need help!!!! Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Clutching i need help!!!! Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Clutching i need help!!!! Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Clutching i need help!!!! Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Clutching i need help!!!! Vote_lcapClutching i need help!!!! Voting_barClutching i need help!!!! Vote_rcap
Brady660
12 posters
Brady660
Clutching i need help!!!! Empty
PostSubject: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:21 pm
I hove a 660 rhino and i am looking into upgrading primary sheave as well as clutch kit. I dont know where to start please help?
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:28 pm
call James first then go from there , he will set you up the sheave ,spring, weights an so on, check your wet clutch out may want to slug it to
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:29 pm
What does slug mean
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:33 pm
add weight to the wet clutch helps the wet clutch not slip as much before it locks up
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:36 pm
What is jame's number
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 2:41 pm
in the vendor section
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 3:03 pm
James at JBS......WV HOTROD Rhino
304-673-2602 or 304-877-3419
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 8:31 pm
JBS Sheave!!!!Clutching i need help!!!! 2016508534
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 9:16 pm
if you own a rhino you need one of James's sheeves Very Happy
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 9:27 pm
It's a must have for all rhinos.
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 9:56 pm
I am going to order the machined sheave and clutch kit with purple spring do you guys think i need the slugs
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeThu May 09, 2013 10:10 pm
I think its better with them, you can read about it on here look up stuntmanmike wet clutch
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeFri May 10, 2013 2:27 pm
Ok guys i just placed my order!! I got the machined sheave, clutch kit with purple spring and 14 weights and also clutch slugs. I am so excited i cant stand it. I hope i will be a jbs beliver after this
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeFri May 10, 2013 2:30 pm
Oh You will !!! It is incredible at what all it does for the Rhino !
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeFri May 10, 2013 10:47 pm
After i make these upgrades what else would you guys recomend. I have a cdi and will have the clutch kit clutch slugs and jbs machined sheave
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeFri May 10, 2013 11:49 pm
cam is my next upgrade maybe a throttle body for my 700 we put a cam in my buds 700 and it flat hauls now night and day difference..
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSat May 11, 2013 1:34 am
I think there's another one been bit by the mod bug , o what a long parts list it will be. now about a better air filter maybe open up the factory snorkel to let that air in, also look into the grinding weld on the header for better flow (that's on here on another tread) Clutching i need help!!!! 2016508534
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSat May 11, 2013 8:54 am
Dancing Banana
Brady660
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSun May 12, 2013 1:36 am
Is the cam a jbs cam that kjrhino is talking about and how much is it
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSun May 12, 2013 8:29 am
you need to add led lights Laughing
http://www.trailbrightled.com
RiverRat
RiverRat
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSun May 12, 2013 11:01 am
Scott do you sell led bars for trucks also? My boss and I are gonna add light to our work. Lol
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSun May 12, 2013 11:09 am
Yep , I will be adding more tonight.
What kind of lights are you looking for? More of a flood light ?
RiverRat
RiverRat
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeSun May 12, 2013 2:50 pm
We spend a lot time on dirt roads so just a good "light up the world" kinda light. Light bar more than likely.
Junglerider
Junglerider
PostSubject: Re: Clutching i need help!!!!   Clutching i need help!!!! Icon_minitimeTue May 21, 2013 6:05 pm
Raptor stage II cam. Hotcams #4005-2. You'll need the spring kit too, and of course tune your carb to match. Makes the 660 so much more fun!
http://www.jungleatv.com
» Rhino 700 clutching??
