Who is online? | In total there are 12 users online :: 0 Registered, 0 Hidden and 12 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Cam for rhino | |
Jason362
Posts : 5 Join date : 2013-05-06 Location : Kentucky
| Subject: Cam for rhino Tue May 14, 2013 8:15 pm | |
| I've been thinking of putting a cam in my Rhino, and was going to see what I could expect out of it? I've seen alot running stage 2 cam, if I get one is there anymore mods I have to make with it when I install it? Also about how much will it set me back $, and where to get it from? Better yet does JBS have them? | |
| | | Brady660
Posts : 17 Join date : 2013-05-09
| Subject: Re: Cam for rhino Tue May 14, 2013 8:33 pm | |
| What did you see from stage two | |
| | | Snorider
| Subject: Re: Cam for rhino Tue May 14, 2013 8:45 pm | |
| you'll need a msd and fuel map or PC V w/fuel map or auto tune to go with it. I think. but you will have to have a fuel controller and map of some sorts. mine isn't as new as yours, but i love my cam. it hits hard in the bottom of the mid range on up. as just for cam only i don't know, cause I put duals on first then later added the cam. | |
| | | Jason362
| Subject: Re: Cam for rhino Tue May 14, 2013 9:06 pm | |
| Thanks Snorider, the biggest reason I want it is, I want the fastest mods that will get me out running Razors in a drag race lol, Brady I've seen some with a stage 2 cam get in the 60's but don't know what other mods they had. All I've got one mine thus far is a JBS sheave got me running 48 MPH | |
| | | ChrisH
| Subject: Re: Cam for rhino Tue May 14, 2013 9:41 pm | |
| Do the cam. It is a game changer. I suggest the Bazzaz fuel controller and the Autotune. It is extremely easy to get a tune that works for your fuel, for your Rhino, and for your riding conditions. You will also need some kind of ignition controller. I think the Dynatek works with your 2013 Rhino.
To get you running with the later model 55HP RZRs, you are going to need an exhaust, in my opinion. I ran the cam and throttle body for a long time with good results, even with stock exhaust. But the exhaust really woke it up. Definitly do the exhaust if you can stand a little more noise. I chose the Muzzys for their tune-ability (open core, quiet core, or whisper core), but if I had to do it again I might buy the Alba exhaust instead.
The JBS sheave, cam, and exhaust will get you to the 8000RPM rev limiter, which is about 60-62MPH. A lot depends on tires and the condition of the belt and such. But none the less, those mods will get your Rhino on 25" Bighorns pretty fast.
The 46mm bored throttle body from Benchmark is also good for a little more power.
James of JBS will get you as fast as you want. Just call him and let him know your budget. | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: Cam for rhino Tue May 14, 2013 9:42 pm | |
| i have what you need in stock | |
| | | Snorider
| Subject: Re: Cam for rhino Tue May 14, 2013 10:26 pm | |
| I figured I was loosing a little with the half windshield, roof, mesh rear and 26in tires. cause I hit 59 on fairly flat gravel road. with slight downhill low to mid 60's. but thats cheating lol. but I would say hit james up and get everything ya need. you will love it. | |
| | | rhino727
| Subject: Re: Cam for rhino Wed May 15, 2013 12:30 am | |
| here goes another mod bug done bit another one ain't it great | |
| | | Hump
| Subject: Re: Cam for rhino Wed May 15, 2013 12:37 am | |
| Jason, when you call James tell him you want my setup. You will run dead even turn to turn on the trails with a rzr s. I just did it the other weekend 0-45 runs through the woods. | |
| | | Hump
| Subject: Re: Cam for rhino Wed May 15, 2013 12:44 am | |
| We ran mine with the cam and no cdi with 18g weights, and it made so much more power that it would hit the stock rev limit at 30mph wide open. 1/4 throttle and it would run up to 49. You will need the cdi to let it rev like it wants. I couldn't imagine mine without the cam. | |
| Subject: Re: Cam for rhino | |
| | | | Cam for rhino | |
