| Snapped a bolt | |
+5WV Hot Rod Rhino rhino727 scottwv ASPENDELLROVER 4x4ff 9 posters |
4x4ff
| Subject: Snapped a bolt Fri May 24, 2013 2:03 am | |
| Well as I'm putting my Rhino back together I snapped a bolt. It's the bottom left one that holds the cage on over the sheave. My question is how critical is it? The other 3 are just fine. Can I leave it as is or should I try to get it out. It looks like it will be a pain!
Steve
| Subject: Re: Snapped a bolt Fri May 24, 2013 2:55 am | |
| if the cage feels tight I wouldnt worry about it, but others may disagree, I don't know shit..lol | |
| Subject: Re: Snapped a bolt Fri May 24, 2013 8:29 am | |
| It probably isn't tight...I would try to get it out , so it doesn't vibrate out on it's own...and...really mess stuff up. | |
| Subject: Re: Snapped a bolt Fri May 24, 2013 9:16 am | |
| did you have the long bolt in the wrong hole ? its been a while but I remember that there's different length bolts on the cage . but I would try to get it out did it brake off flush with case | |
| Subject: Re: Snapped a bolt Fri May 24, 2013 9:42 am | |
| get a left hand drill bit and it will prolly back it out | |
4x4ff
| Subject: Re: Snapped a bolt Fri May 24, 2013 11:23 am | |
| The cage is tight And the snapped off part is in pretty far. I just over-torqued it.
Steve
| Subject: Re: Snapped a bolt Fri May 24, 2013 11:45 am | |
| bottom left is the one with the dowel.. | |
4x4ff
| Subject: Re: Snapped a bolt Fri May 24, 2013 6:56 pm | |
| James,
Does the dowel make a difference?
Steve
4x4ff
| Subject: Re: Snapped a bolt Fri May 24, 2013 7:46 pm | |
| Ok all,
Upon further closer examination this thing is going to suck trying to get out. I have tried to drill it without any success. The way it snapped its tough to get a punch on it. How bad will my problems be if I leave it off?
Steve
The author of this message was banned from the forum - See the message |
Polarblu
Posts : 30 Join date : 2013-05-18
| Subject: Re: Snapped a bolt Fri May 24, 2013 8:44 pm | |
| It's doweled so up and down movement or "lateral" is taken care of. The clutch isn't going to walk out of the case. Run it!!
| Subject: Re: Snapped a bolt Fri May 24, 2013 8:53 pm | |
| i think it will be fine to if you cant get it out | |
| Subject: Re: Snapped a bolt Sat May 25, 2013 7:00 pm | |
| If the bolt didn't bottom out in the hole, only the head tightened up against the bearing cage. I would think it should come out fairly easy. Did you pull the dowel and try to remove it? If your going to leave it in make sure you put some silicone on the broken bolt to prevent it from vibrating out and doing a lot of damage. | |
4x4ff
| Subject: Re: Snapped a bolt Mon Jun 17, 2013 5:40 pm | |
| FWIW, I was able to remove the broken bolt using one of these nifty gadgets. I use the 3/16" size. I couldn't find one in metric. The nice thing is it slid right into the recessed hole that the bolt broke off in. Steve | |
Workhorserhino
| Subject: Re: Snapped a bolt Mon Jun 17, 2013 6:41 pm | |
| Nice job. | |
RiverRat
| Subject: Re: Snapped a bolt Mon Jun 17, 2013 11:52 pm | |
| That bolt was bouncing around in my belt cover when I pulled it apart to service the sheave. Lucky it didn't trash something. | |
| Subject: Re: Snapped a bolt | |
| Snapped a bolt | |
