In total there are 37 users online :: 0 Registered, 0 Hidden and 37 Guests :: 2 Bots
Radiator relocate ?? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Radiator relocate ?? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Radiator relocate ?? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Radiator relocate ?? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Radiator relocate ?? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Radiator relocate ?? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Radiator relocate ?? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Radiator relocate ?? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Radiator relocate ?? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Radiator relocate ?? Vote_lcapRadiator relocate ?? Voting_barRadiator relocate ?? Vote_rcap
5 posters
tjt603
tjt603
Radiator relocate ?? Empty
PostSubject: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 9:56 am
Went out riding yesterday and hit a few mud holes. I started over heating for the first time ever. What are my options on moving radiator some where eles. It was full of mud and hard to clean out.
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 10:26 am
do you have a set of shields from James? they help... Also, you need to clean it gggggggooooooooooooooooooooooodddddddddddddd..........
removing the oil cooler or get something to stick between them to push the mud out.... also, it helps a bit if you cut some holes in the bottom of your fan shroud to let all the garbage out..... i do all that before i relocate it... Unless its just a MUD rhino, then stick it behind your head... It just get a little warm in the cab during summer time..... Hope that helps
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 12:41 pm
I want to move my oil cooler to get easier access to the radiator.
JOHN DILLARD
JOHN DILLARD
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 2:45 pm
Get a piece of 3/8 steel fuel line flatten one end drill 1/16 holes vertically adapt other end to garden hose. U can stick it in between oil cooler and rad and flush core until water runs clean.do this every time you ride. If you play in deep mud take this and a 12 volt weed sprayer pump with ya for trail cleaning.
tjt603
tjt603
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 3:11 pm
Where do you get the 12v weed sprayer pump? What does it look like?
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 3:28 pm
tractor supply / northern
tjt603
tjt603
PostSubject: Re: Radiator relocate ??   Radiator relocate ?? Icon_minitimeMon May 27, 2013 5:09 pm
does anyone have a installed pic of the new add on radiator guard?
» radiator relocate
» Radiator refill
» relocate radiator 08 rhino 700
» Radiator Fan
» radiator fan
