In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests :: 2 Bots
Torn CV boot Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Torn CV boot Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Torn CV boot Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Torn CV boot Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Torn CV boot Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Torn CV boot Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Torn CV boot Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Torn CV boot Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Torn CV boot Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Torn CV boot Vote_lcapTorn CV boot Voting_barTorn CV boot Vote_rcap
 Torn CV boot
chalkminer
8 posters
chalkminer
chalkminer
Torn CV boot Empty
PostSubject: Torn CV boot   Torn CV boot Icon_minitimeThu May 30, 2013 10:50 pm
I just noticed I have a torn CV boot on the left side of the rear diff. From what I can tell the CV is still ok, so I was planning to clean it up repack it and just put a new boot on it. I have had the rhino for a while but have not done much work on it yet, so I thought I'd ask for tip or tricks on this. Should I just go with a OEM boot? Any special tools required? How much time should a rookie like myself budget for the job?
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeThu May 30, 2013 11:07 pm
JBS has the best kits and best price on them. Not bad to change at all, just be sure and get the joint real clean.
After You ride it a little, be sure and check for leak.
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 1:01 am
I like to use a CV banding tool to make sure the CV band is nice and tight so no grease spins out as Larry said
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 2:14 am
x2 just don't torque it to much because they can break! lol!
chalkminer
chalkminer
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 2:39 am
Are all of the banding tools created equal? I did a check on Amazon and they had some different styles to choose from starting at less than 10 bucks. Is there a particular style that works best?
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 9:23 am
My personal experience with CVs is that once you have a tear the CV is usually shot. I've changed two boots only to go back and change the CV a week later. I now just pay the extra for a new CV that comes with a boot and have a few extra 'questionable' CVs laying around if I get in a jam...plus breaking down a CV and cleaning it is a complete pain in the ass!
Could be that I just didn't notice the tear in time but I check them before and after every ride. If you're questioning the CV...just change it while you have it apart.
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 10:30 am
if you wanna spend the cash, buy a sti axle and fix the other one for a later issue... Thats how i ended up with 4 replacments and now i cant seem to break them ... lol!
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 12:37 pm
What year rhino are you working on?
Yamaha uses two different bands, one type does not need a banding tool.
I like the Yamaha boot kits, they come with everything needed, boot, bands, grease, snap rings and and c- clips.
Moose kits suck!!!
chalkminer
chalkminer
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 12:59 pm
It is a 2007 660.
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 1:08 pm
i bought mine from amazon for like 25 bucks and it works great. it allows you to tighten the band then cut it. i figured it is a tool I will only use once and awhile and I not making a living with it..lol
thekrust
thekrust
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeFri May 31, 2013 2:06 pm
EPI also sells a kit that has everything you need to do the job(boot, grease, bands) for about $20. They have a tool too that costs about $2, not fancy but gets the job done. As said above, clean it real good and it is a pain but you'll be good to go.Very Happy
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeMon Jun 03, 2013 11:34 pm
chalkminer wrote:
It is a 2007 660.
No special tool is needed for the boots on a '07 when using Yamaha boot kits.
chalkminer
chalkminer
Torn CV boot Empty
PostSubject: Re: Torn CV boot   Torn CV boot Icon_minitimeTue Jun 04, 2013 12:15 am
Thanks for the tips! I called up JBS and got a Yamaha boot kit on the way. Even with the shipping it was still cheaper then buying it local.
Torn CV boot Empty
Torn CV boot
» cv boot
» New CV Boot?
» cv boot
» CV Boot Tore
» BOOT TROUBLES
