| New CV Boot? | |
+5onebuilder madmax 1 scottwv CUSTOMIZEDRHINO13 ASPENDELLROVER 9 posters |
| Subject: New CV Boot? Mon Apr 22, 2013 6:34 pm | |
| I need a new front inner CV boot, tore it the last day in the dez(must have been a tweakers needle that flew up while I was doing 40 thru the 2' woops..lol), thank god! From my small amount of knowledge compared to you guys, I want OEM boot? So tell me if I'm wrong, I need to purchase a cv band tool, cv bands, grease and a boot, c clips and snap ring? I found some silicone boots from for 8 bucks a piece, should I buy everything seperate or get the OEM kit? Thanks for your time! | |
| Subject: Re: New CV Boot? Mon Apr 22, 2013 7:37 pm | |
| You definitely need that band tool, be careful though if you only buy one band and pull it too hard they can break . | |
| Subject: Re: New CV Boot? Mon Apr 22, 2013 9:06 pm | |
| thanks, now what else do I need to know? | |
| Subject: Re: New CV Boot? Mon Apr 22, 2013 9:45 pm | |
| Hold your tonge out to the left while working lol I would use oem but I don't much about long travel. | |
| Subject: Re: New CV Boot? Mon Apr 22, 2013 10:57 pm | |
| I wouldn't fool with anything but the oe boots...I've used the cheapo's ; but , they don' hold up !! Call up our bud , and have him ship you one ( you're gonna be better off in the long run)...you can use a GOOD pair of pliers/needle-noses on the oe bands. | |
| Subject: Re: New CV Boot? Mon Apr 22, 2013 11:00 pm | |
| Good info my cousin had the band tool. | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 8:37 pm | |
| ok guys, it just came to me, I'm gonna use the cv boot off my stock axles. What grease do I need to repack it? this should save me some cash so I can get my power steering..lol...and 2 mother's day presents which is coming up soon..lol | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 8:47 pm | |
| for the price not a bad idea to have a spare one no wait or risk of damage to the joint you know the cv joint haha | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 8:51 pm | |
| so what grease do I use mick? I have 4 spare axles with cv and no one wants em so might as well use the boots and cv's right? | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 9:08 pm | |
| bought a spare from Yamaha w/ grease bin 11/2 yr ago better ask you know who | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 9:20 pm | |
| - CustomizedRhino13 wrote:
- You definitely need that band tool, be careful though if you only buy one band and pull it too hard they can break .
What year did Yamaha change over to the new style clamp? I hate them. Love the old style. | |
| Subject: Re: New CV Boot? Tue Apr 23, 2013 9:39 pm | |
| I don't know we went down to the dealer and bought one, my boot wasn't torn but just folded in, turned out it just poped back into place. While were torqueing the band it broke. I don't remember how but we took a piece from the old and new one and made it work! | |
| Subject: Re: New CV Boot? Wed Apr 24, 2013 9:01 am | |
| - ASPENDELL ROVER wrote:
- so what grease do I use mick? I have 4 spare axles with cv and no one wants em so might as well use the boots and cv's right?
I'm sure someone will chime in and I'll get reprimanded for bad advice (lol)...but...I have used good , high-temp wheel bearing grease (either the black , or red...I've used both) without any problem. | |
| Subject: Re: New CV Boot? Wed Apr 24, 2013 9:46 am | |
- I don't know we went down to the dealer and bought one, my boot wasn't torn but just folded in, turned out it just poped back into place. While were torqueing the band it broke. I don't remember how but we took a piece from the old and new one and made it work!
If you had to use a band tool on your '06 660 boot, it wasn't a Yamaha boot kiit. Every now and then I see one of my boot collapse after a ride. Check it later and it's ok. | |
| Subject: Re: New CV Boot? Wed Apr 24, 2013 11:06 am | |
| [img] [/img] book says moly | |
chalkminer
| Subject: Re: New CV Boot? Wed Apr 24, 2013 12:17 pm | |
soarkrebel
| Subject: Re: New CV Boot? Sun May 05, 2013 8:56 am | |
| I have changed more then my share of boots. I prefer Duraboot brand over OEM on all my machines. They are tougher and cost less. I also keep several Napa CV bands in the garage because I prefer them. Here is a link to a company that sells kits....maybe James should see if He can buy them and get a little discount. http://www.motormasteratv.com/ | |
| Subject: Re: New CV Boot? Thu Jun 06, 2013 10:10 pm | |
| You should always use the the CV joint grease because of the way it lubes and gets in all the nooks and cranies,will last longer. High temp wheel bearing grease does not flow so much it relies on centrifugal force. | |
| Subject: Re: New CV Boot? Fri Jun 07, 2013 12:42 am | |
| - soarkrebel wrote:
- I have changed more then my share of boots. I prefer Duraboot brand over OEM on all my machines. They are tougher and cost less.
I also keep several Napa CV bands in the garage because I prefer them. Here is a link to a company that sells kits....maybe James should see if He can buy them and get a little discount. http://www.motormasteratv.com/ Those look like the Same boots Moose sells. Moose boots suck! They don't fit and have a tendency to slip off. Yamaha boots have a lip on the inside that fit into the grooves on the knuckle. They also come with the hardware you should replace when pulling the axle. | |
| Subject: Re: New CV Boot? | |
| New CV Boot? | |
