| out on the trail | |
+6honda450sfm RhinoGT350 Yotehunter66 thekrust m1n1ster tjt603 10 posters |
tjt603
| Subject: out on the trail Mon Jun 03, 2013 4:31 pm | |
| what do yall use out on the trail to clean the mud off your radiator ? Im getting the radiator guards from James this week. | |
m1n1ster
Posts : 29 Join date : 2013-04-27 Age : 51 Location : Newport, TN
| Subject: Re: out on the trail Mon Jun 03, 2013 6:40 pm | |
| I'm interested too! Kinda wondered if a pressure sprayer that you pump up would work? | |
thekrust
| Subject: Re: out on the trail Mon Jun 03, 2013 8:42 pm | |
| A creek and some velocity,,,and it's fun too!! | |
Yotehunter66 Moderator
| Subject: Re: out on the trail Mon Jun 03, 2013 9:22 pm | |
| - thekrust wrote:
- A creek and some velocity,,,and it's fun too!!
x2. | |
RhinoGT350
| Subject: Re: out on the trail Mon Jun 03, 2013 9:51 pm | |
| how much are the brush guards? | |
| Subject: Re: out on the trail Mon Jun 03, 2013 9:57 pm | |
| - Quote :
This doesn't work. It may get a tiny bit off the front but will not get in between the fins if it's caked in there. YOu need to get right in there with fairly decent water pressure to get it good. Only true way to get it completely clean is removal of the rad and then soak it. | |
| Subject: Re: out on the trail Mon Jun 03, 2013 10:13 pm | |
| we have a 12 volt pump goes on a sprayer , just find some sorta clean water an wash till ya happy , pump two hoses two alligator clips good ta go | |
Mrs. Hot Rod Admin
| Subject: Re: out on the trail Mon Jun 03, 2013 10:43 pm | |
| Once you get your shields all you have to do is make sure your radiator is completely clean when you start out .... you should be able to shine a light all the way through if it's good n clean. Before the shields if we rode a half day it was covered & overheating, now we can ride all weekend without spraying out the radiator or having any problems =) | |
| Subject: Re: out on the trail Mon Jun 03, 2013 10:45 pm | |
| Spray on some Aluminum bright and it will foam up and fall off with just hose presure, And look like new when your done. | |
| Subject: Re: out on the trail Mon Jun 03, 2013 10:54 pm | |
| - Stuntmanmike wrote:
- Spray on some Aluminum bright and it will foam up and fall off with just hose presure, And look like new when your done.
hey Mike, is that the same stuff they use to clean air conditioner fins? i heard that was diluted muriatic acid. do they show the ingredients on the bottle/can? | |
| Subject: Re: out on the trail Mon Jun 03, 2013 11:09 pm | |
| It is similar, there is no muratic acid, It has phosphourous acid and some of the same other filler. | |
| Subject: Re: out on the trail Mon Jun 03, 2013 11:29 pm | |
- It is similar, there is no muratic acid, It has phosphourous acid and some of the same other filler.
o.k. thanx. have to pick some up | |
| Subject: Re: out on the trail | |
