In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests :: 1 Bot
out on the trail Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
out on the trail Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
out on the trail Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
out on the trail Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
out on the trail Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
out on the trail Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
out on the trail Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
out on the trail Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
out on the trail Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
out on the trail Vote_lcapout on the trail Voting_barout on the trail Vote_rcap
 out on the trail
RhinoGT350
Yotehunter66
thekrust
m1n1ster
tjt603
10 posters
tjt603
tjt603
out on the trail Empty
PostSubject: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 4:31 pm
what do yall use out on the trail to clean the mud off your radiator ? Im getting the radiator guards from James this week.
m1n1ster
m1n1ster
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 6:40 pm
I'm interested too! Kinda wondered if a pressure sprayer that you pump up would work?
thekrust
thekrust
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 8:42 pm
A creek and some velocity,,,and it's fun too!!Smile
Yotehunter66
Moderator
Yotehunter66
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 9:22 pm
x2.
RhinoGT350
RhinoGT350
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 9:51 pm
how much are the brush guards?
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 9:57 pm
Quote :
This doesn't work. It may get a tiny bit off the front but will not get in between the fins if it's caked in there.
YOu need to get right in there with fairly decent water pressure to get it good. Only true way to get it completely clean is removal of the rad and then soak it.
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 10:13 pm
we have a 12 volt pump goes on a sprayer , just find some sorta clean water an wash till ya happy , pump two hoses two alligator clips good ta go
Mrs. Hot Rod
Mrs. Hot Rod
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 10:43 pm
Once you get your shields all you have to do is make sure your radiator is completely clean when you start out .... you should be able to shine a light all the way through if it's good n clean. Before the shields if we rode a half day it was covered & overheating, now we can ride all weekend without spraying out the radiator or having any problems =)
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 10:45 pm
Spray on some Aluminum bright and it will foam up and fall off with just hose presure, And look like new when your done.
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 10:54 pm
hey Mike, is that the same stuff they use to clean air conditioner fins?
i heard that was diluted muriatic acid. do they show the ingredients on the bottle/can?
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 11:09 pm
It is similar, there is no muratic acid, It has phosphourous acid and some of the same other filler.
PostSubject: Re: out on the trail   out on the trail Icon_minitimeMon Jun 03, 2013 11:29 pm
o.k. thanx. have to pick some up bounce
out on the trail
» Blazing a new trail
» Trail Riding!
» what ya think about the new wildcat trail?
» Troubles on the trail
» trail opened with D-9
