| Clutch cover gasket / o-ring | |
4x4ff
| Subject: Clutch cover gasket / o-ring Sun Jun 16, 2013 5:13 pm | |
| I realize I'm probably preaching to the choir here but I do occasionally ride through water. Last time I had the crankcase/clutch cover off the o-ring/gasket around it looked pretty smooshed (thats probably not a real word...lol) so I ordered another one from james and OMG what a difference. I know the o-ring is reuseable but just pointing out what a difference between the old one and the new one. I feel much better about going through water now. They really aren't that expensive.
Steve | |
| Subject: Re: Clutch cover gasket / o-ring Sun Jun 16, 2013 5:20 pm | |
| did you slug your wet while you were in there? thinking about doing it, its all I have left besides the motor which aint gonna happen till she blows! | |
4x4ff
| Subject: Re: Clutch cover gasket / o-ring Sun Jun 16, 2013 6:45 pm | |
| No, I haven't done that yet. I replaced my clutch with a slightly used one. I figure what I'll do is next time I get into it I'll look into slugging. I'm not a need for speed kinda guy. I just want reliability. The P.O. of my rhino had placed a JBS sheave in it. I just greased it and had to buy the grease cap for the sheave. Also replaced the belt because I ruined it getting covered in grease from when I didn't have the grease cover on. Kinda a 'doh' experience.
Steve | |
thekrust
| Subject: Re: Clutch cover gasket / o-ring Sun Jun 16, 2013 9:11 pm | |
| I did the slug thing for one of my customers, WOW, what a difference. I will be doing my own as soon as I have an excuse to go in there. For sure if you have that open put in the slugs. | |
| Subject: Re: Clutch cover gasket / o-ring Sun Jun 16, 2013 10:44 pm | |
| love my slugs...600 + miles..gonna check it at 1000 | |
| Subject: Re: Clutch cover gasket / o-ring Mon Jun 17, 2013 1:56 am | |
| I'm no mechanic, though have never had any problems with the work I have done on my rhino, so the question is...how difficult is the wet clutch and do I need any special tools or odd socket sizes? | |
| Subject: Re: Clutch cover gasket / o-ring Mon Jun 17, 2013 6:41 am | |
| If you are just talking about replacing it its not that bad to do and no special tools are needed I just replaced my buddy's wet clutch and one way bearing it took about 2 hrs all together and it was our first time. | |
4x4ff
| Subject: Re: Clutch cover gasket / o-ring Mon Jun 17, 2013 9:28 am | |
| As Trhino said it isn't very tough at all. Make sure you have a GOOD electric or air impact for the primary and secondary nuts. After you get them off and the clutch cover you will need it again to get another nut off the clutch but remember that one is left hand thread and is punched or dimpled so it won't come off. A copy of the service manual helps just to give you some pointers. Remember to drain the oil before you take the inner clutch cover. In a 700 it makes it much easier to take the drivers seat mount out to access it easier.
Steve | |
| Subject: Re: Clutch cover gasket / o-ring Mon Jun 17, 2013 1:51 pm | |
| cool, next time I open her up to check the primary guess I'll pull the wet clutch and slug it. Hey James, post us a video when you inspect your slugs at 1000 miles, it would help, you got a video for everything else...lol...thx | |
| Subject: Re: Clutch cover gasket / o-ring Mon Jun 17, 2013 3:28 pm | |
| Subject: Re: Clutch cover gasket / o-ring | |
