In total there are 43 users online :: 0 Registered, 0 Hidden and 43 Guests :: 2 Bots
Help! Gasket mis-match Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Help! Gasket mis-match Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Help! Gasket mis-match Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Help! Gasket mis-match Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Help! Gasket mis-match Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Help! Gasket mis-match Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Help! Gasket mis-match Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Help! Gasket mis-match Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Help! Gasket mis-match Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Help! Gasket mis-match Vote_lcapHelp! Gasket mis-match Voting_barHelp! Gasket mis-match Vote_rcap
Help! Gasket mis-match Empty
PostSubject: Help! Gasket mis-match   Help! Gasket mis-match Icon_minitimeSat Sep 28, 2013 4:06 pm
I don't know how to attach images here, dont see the attachment icon. Anyhew, I am installing my new CP 102 piston that came with a cometic gasket kit. There is an oil galley on the passenger side that previously terminated at the gasket. The new gasket is open in that spot leaving the galley open to the inside of the case. Can anybody tell me about this problem??
PostSubject: Re: Help! Gasket mis-match   Help! Gasket mis-match Icon_minitimeSat Sep 28, 2013 4:37 pm
Make that driver side...
» wet clutch cover gasket?
» Clutch cover gasket / o-ring
