In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests :: 2 Bots
Busted front dif Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Busted front dif Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Busted front dif Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Busted front dif Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Busted front dif Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Busted front dif Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Busted front dif Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Busted front dif Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Busted front dif Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Busted front dif Vote_lcapBusted front dif Voting_barBusted front dif Vote_rcap
 Busted front dif
3 posters
sls666
sls666
Busted front dif Empty
PostSubject: Busted front dif   Busted front dif Icon_minitimeSat Jun 22, 2013 8:21 am
So i ended up breaking my front dif again-second time now so no big deal.  Took it to the local welding shop and they decided to split it open to do it right.   Now that it is split should i put new a bearing in?or what will need to rebuild it.  Seals?
PostSubject: Re: Busted front dif   Busted front dif Icon_minitimeSun Jun 23, 2013 11:08 am
While you got it open , I would do a complete rebuild. Seals and bearings are cheap.
PostSubject: Re: Busted front dif   Busted front dif Icon_minitimeSun Jun 23, 2013 12:13 pm
in stock!!
sls666
sls666
PostSubject: Re: Busted front dif   Busted front dif Icon_minitimeSun Jun 23, 2013 7:22 pm
Ok sounds like a plan.   Is there any aftermarket kits that are stronger.  If im doing it i want this to be the last time?
Busted front dif
» FRONT FRAME SUPPORT
» Front driveshaft
» FRONT SEATS
» Front Gusset
» Rt front tire turned out
