In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 2 Bots
Gauge ?? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Gauge ?? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Gauge ?? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Gauge ?? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Gauge ?? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Gauge ?? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Gauge ?? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Gauge ?? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Gauge ?? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Gauge ?? Vote_lcapGauge ?? Voting_barGauge ?? Vote_rcap
 Gauge ??
4 posters
Rawhide
Rawhide
Gauge ?? Empty
PostSubject: Gauge ??   Gauge ?? Icon_minitimeWed Jun 26, 2013 7:44 pm
when using a T in line for sending unit on temp gauge on pictures i see a ground wire on the T my question is where does that attach ???
to the gauge itself or frame or  - side of battery
thanks in advance scratch
TBOMB
Gauge ?? Empty
PostSubject: Re: Gauge ??   Gauge ?? Icon_minitimeWed Jun 26, 2013 8:08 pm
You really need to check this site for grounding upgrades over the stock system. That being said, if you are stock you can connect to the neg. side of battery, but I suggest that you upgrade your grounding. One of our members (STEVES) has done extensive threads on this and I would check them out if I were you. Good luck and if I can provide any further help let me know.
Gauge ?? Empty
PostSubject: Re: Gauge ??   Gauge ?? Icon_minitimeWed Jun 26, 2013 8:21 pm
TBOMB is rite this man really knows his business he has a couple postings on here talking about the issue and they are very informative. An by the sounds of reading some other posts if people could have seen his posts just a little earlier it could have saved them a lot of trouble.
Gauge ?? Empty
PostSubject: Re: Gauge ??   Gauge ?? Icon_minitimeWed Jun 26, 2013 11:37 pm
I ran mine back to the gauge and added another wire from the gauge back to my ground block.
Gauge ?? Empty
Gauge ??
» Which gauge are you using?
» Help with lc-1 afr gauge
» A/F Gauge Needed?
» Gauge install
» innovate a/f gauge
