| belt burning up.. need help | |
dognhogs
Posts : 21 Join date : 2013-03-21 Age : 34 Location : Arkansas
| Subject: belt burning up.. need help Tue Jul 16, 2013 9:12 pm | |
| I bought a jbs kit about 4 months ago and was having real good luck with it. Then I had a belt burn up. I tore into it and installed a new belt. Before putting it all back together I started it and let it idle for a bit. I could smell it getting hot so I killed it. Went to feeling around and the plate/sheave thing that runs on same shaft as clutch is hotter than hell. Does anyone have any clue what I need to do. Bare with me I'm a newbie!! I did regrease and clean the clutch. It seems to be in good shape and stay fairly cool when running its just the other plate. Thanks for advice.. | |
| Subject: Re: belt burning up.. need help Tue Jul 16, 2013 9:18 pm | |
| was it an oem (yamaha) belt?
when it was running did the belt move up and down on the sheave? | |
| Subject: Re: belt burning up.. need help Tue Jul 16, 2013 10:08 pm | |
dognhogs
| Subject: Re: belt burning up.. need help Tue Jul 16, 2013 10:22 pm | |
| - 08Rhino450SE wrote:
- was it an oem (yamaha) belt?
when it was running did the belt move up and down on the sheave? the belt was a belt from James and yes it moves like it is supposed to. I've called James but couldn't get ahold of him. i know he's a busy man. | |
| Subject: Re: belt burning up.. need help Tue Jul 16, 2013 10:24 pm | |
| Keep tring,hes a busy man...... | |
dognhogs
| Subject: Re: belt burning up.. need help Tue Jul 16, 2013 10:58 pm | |
| is there anywhere I can get a picture of what the teeth are suppose to look like on the plate I'm talking about | |
| Subject: Re: belt burning up.. need help Wed Jul 17, 2013 1:40 am | |
| The camplate?
Last edited by CUSTOMIZEDRHINO13 on Wed Jul 17, 2013 12:29 pm; edited 1 time in total | |
dognhogs
| Subject: Re: belt burning up.. need help Wed Jul 17, 2013 7:16 am | |
| not the cam plate. Its the sheave that's closest to the motor that the belt runs off of. Is it suppose to be geared to the shaft at all times or is it gonna move freely.. is there a washer or something I lost that's keeps it out on the gears so it spins same time as clutch and all. | |
dognhogs
| Subject: Re: belt burning up.. need help Wed Jul 17, 2013 10:29 am | |
| problem solved guys. Was able to get ahold of James and get what I needed. Thanks for the help everyone. | |
| Subject: Re: belt burning up.. need help Wed Jul 17, 2013 10:34 am | |
| what was it? | |
| Subject: Re: belt burning up.. need help Wed Jul 17, 2013 11:29 am | |
| Subject: Re: belt burning up.. need help | |
