| what belt to go with | |
+4JBFIREMAN Yotehunter66 WV Hot Rod Rhino meats 8 posters |
meats
| Subject: what belt to go with Tue Mar 12, 2013 7:13 am | |
| i have an 04 660 what am i going to gain with going to a 700 belt instead of the 660 belt, and do i get an oem or an aftermarket belt. it is all stock except for a msd charge cdi. hopefully a jbs sheave setup in the next week or two. thanks for the info | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 8:29 am | |
| its just stronger...has kevlar....700 oem belt only | |
meats
| Subject: Re: what belt to go with Tue Mar 12, 2013 8:38 am | |
| how much does the belt cost | |
Yotehunter66 Moderator
| Seems the OEM belt is the preferred for all the rhinos. | |
JBFIREMAN
| Subject: Re: what belt to go with Tue Mar 12, 2013 3:51 pm | |
| OME Call James he's got a good price on them | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 3:55 pm | |
| - meats wrote:
- how much does the belt cost
100.00 | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 3:57 pm | |
| in stock and 2-3 days shipping | |
Foxman92
Posts : 13 Join date : 2013-03-11
| Subject: Re: what belt to go with Tue Mar 12, 2013 4:14 pm | |
| I went down to napa got a geforce napa belt.. Cross-reference a gates belt for a 700 cost me 54 bucks.. Figured it was worth a shot.. I picked up 3mph so i guess mine was slipping | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 5:53 pm | |
| i would carry a spare in case it dont hold up you wont be stranded....width has alot to do with top speed..some are wider than stock...you gain top but you lose some bottom and its hard on the wet clutch .....its like pulling out in second every time in your car....look at it and see when its stopped is the belt all the way to the top of the secondary if it is you should be fine other than durability... | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 6:01 pm | |
| ...the yamaha belt is the only belt i have ever seen hold up so that is what we will push .....quality and what we know works... | |
meats
| Subject: Re: what belt to go with Tue Mar 12, 2013 6:11 pm | |
| thanks for the info. its better to go with what is proven. james my extra rhino funds are almost built up enough to get your sheave kit and i might as well get the belt from you also. thanks again | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 6:15 pm | |
| I agree with James. The Rhino 700 belt is what you want to run whether you got a 660 or a 700. We punish the belts in mud and water with big tires. The belt is not the weak link in a Yamaha. With a good OEM belt, I think you'll blow a CV before the belt smokes. | |
| Subject: Re: what belt to go with Tue Mar 12, 2013 6:32 pm | |
| - meats wrote:
- thanks for the info. its better to go with what is proven. james my extra rhino funds are almost built up enough to get your sheave kit and i might as well get the belt from you also. thanks again
just let me know..thanks | |
Bender.chris5908
Posts : 33 Join date : 2013-03-11 Location : Central pa
| Subject: Re: what belt to go with Tue Mar 12, 2013 10:33 pm | |
| oem belt has held up the best for me also..
Last time i looked a belt up at work(yama dealer) The 660 belt was superseded to the 700.. so there all the same now! | |
chammons
Posts : 14 Join date : 2013-03-10 Age : 43 Location : Fayetteville, AR
| Subject: Re: what belt to go with Tue Mar 12, 2013 11:27 pm | |
| I watched a brand new Gates belt get shredded in a JBS sheave.. I advised against his aftermarket decision, It was on a week long Utah trip. He was very disappointed to be towed back to camp. | |
| Subject: Re: what belt to go with | |
