In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests :: 1 Bot
660 miss at part throttle Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
660 miss at part throttle Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
660 miss at part throttle Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
660 miss at part throttle Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
660 miss at part throttle Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
660 miss at part throttle Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
660 miss at part throttle Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
660 miss at part throttle Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
660 miss at part throttle Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
660 miss at part throttle Vote_lcap660 miss at part throttle Voting_bar660 miss at part throttle Vote_rcap
3 posters
yjwrangler95
660 miss at part throttle Empty
PostSubject: 660 miss at part throttle   660 miss at part throttle Icon_minitimeThu Jul 18, 2013 11:20 am
I have a 660 and noticed a slight miss at part throttle, say at 20mph or so.  It runs fine at wide open ect.  I didn't notice it before I installed the Dynatek cdi, I think it is more pronouncded now.  It is bone stock beside the cdi, sheave, and uni filter, stock jetting, fuel pump ect.  Gas is good, 87 octane.  Starts good pulls hard.
Anyone ever heard of this?  I was going to change the plug and see if that helps, just curious if anyone has had the same issue.
Thanks
Derek
PostSubject: Re: 660 miss at part throttle   660 miss at part throttle Icon_minitimeThu Jul 18, 2013 1:09 pm
take the box back off and try it
Tunderslimer
Tunderslimer
PostSubject: Re: 660 miss at part throttle   660 miss at part throttle Icon_minitimeFri Jul 19, 2013 11:02 am
I had a weird mid range miss once... after you test the CDI box as suggested take a look at #15 in this pic:
660 miss at part throttle Carb
Mine was plugged up a little and dirty... once I cleaned it up bam no more miss.
» Ebay F'up , no not on there part , on my part
» Engine miss and top end problems
» 660 Top speed what am I missing?
» Pin the throttle/hang on!!
» 09 Throttle body, complete
