In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests :: 2 Bots
Engine miss and top end problems Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Engine miss and top end problems Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Engine miss and top end problems Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Engine miss and top end problems Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Engine miss and top end problems Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Engine miss and top end problems Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Engine miss and top end problems Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Engine miss and top end problems Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Engine miss and top end problems Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Engine miss and top end problems Vote_lcapEngine miss and top end problems Voting_barEngine miss and top end problems Vote_rcap
4 posters
Randy3451
Randy3451
Engine miss and top end problems Empty
PostSubject: Engine miss and top end problems   Engine miss and top end problems Icon_minitimeSun Mar 31, 2013 9:42 pm
Alright guys, need your help!!!
Had a shop put a cam and sheave in my 2012 Rhino from James, after wards it wouldn't idol hardly at all, but James said that was normal until my Dynatek and Bazzaz fuel controller was installed. Now it idols ok but has a pretty good miss between 14-20 mph, and my top end isn't where it needs to be, according to James. We adjusted the valves thinking that was it but still the same. I'm ok with the top end, but any ideas on what I should do or check?? James had me check my timing, as hard as it was to see, I think it is right. Maybe i need to go let a mechanic look at it. Lol. Any help would appreciated, thx, Randy.
PostSubject: Re: Engine miss and top end problems   Engine miss and top end problems Icon_minitimeSun Mar 31, 2013 11:17 pm
You need to be positive your Cam is timed right before you make any changes, If your not sure about it have someone look at it for you. It could save you alot of trouble and time.
PostSubject: Re: Engine miss and top end problems   Engine miss and top end problems Icon_minitimeMon Apr 01, 2013 2:39 pm
...did you do a throttle body too...check the tps if you did...call me....i hate when something just aint right...we will find it though..i will send you new boxes if i have too
PostSubject: Re: Engine miss and top end problems   Engine miss and top end problems Icon_minitimeTue Apr 02, 2013 3:21 am
The cam and sheave setup is flawless when everything is right. When you find and fix your problem, you will love it.
» Engine problems
» 660 miss at part throttle
» Ran into problems
» Progressive Problems?
» iPad problems.
