In total there are 47 users online :: 0 Registered, 0 Hidden and 47 Guests :: 1 Bot
Steering box Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Steering box Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Steering box Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Steering box Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Steering box Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Steering box Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Steering box Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Steering box Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Steering box Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Steering box Vote_lcapSteering box Voting_barSteering box Vote_rcap
 Steering box
4 posters
Unit6666
Steering box Empty
PostSubject: Steering box   Steering box Icon_minitimeWed Jul 17, 2013 11:32 pm
My steering box is kinda squeaky when I turn it slow... Is that normal and is there anyway to get fresh grease inside there?
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeWed Jul 17, 2013 11:35 pm
most of the time its a ball joint..might wanna check for a torn boot
Unit6666
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeThu Jul 18, 2013 12:13 am
I will look but it only does it when I turn the wheels at all.. I tried to wiggle the tires vertically no noise and no play.... Probably is a dry joint.. But is there a way to get some grease into the steering box? Could I just pull a boot back and put some in there? Thank you
Workhorserhino
Workhorserhino
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeThu Jul 18, 2013 8:54 am
no the rack is sealed you can't get grease in by removing the bootyou might want to check the steering shaft u joints also they could be squeaking
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeThu Jul 18, 2013 9:38 am
thats when a ball joint does it ...when you move the wheel
Unit6666
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeMon Jul 22, 2013 10:44 pm
So I took benzos advice from some posts I've seen elsewhere and I got a grease needle poked a little hole and pumped the grease to it... The noises went away.. Thank god!!!
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeTue Jul 23, 2013 2:02 am
who is benzo? Oh ya, didn't know James gardener works on rhino's too. lol
Unit6666
Steering box Empty
PostSubject: Re: Steering box   Steering box Icon_minitimeTue Jul 23, 2013 1:56 pm
Ohhhh yeah benzo was from rhino forums... I got his name confused with berto from this forum..
Steering box Empty
Steering box
» Power Steering?
» Steering problem ??????
» Steering wheel
» tie rod ends and steering joint
» For Sale steering wheel
HOTRODRHINOFORUMS.COM :: Technical :: drivetrain-
