In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests :: 2 Bots
Steering problem ?????? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Steering problem ?????? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Steering problem ?????? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Steering problem ?????? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Steering problem ?????? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Steering problem ?????? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Steering problem ?????? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Steering problem ?????? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Steering problem ?????? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Steering problem ?????? Vote_lcapSteering problem ?????? Voting_barSteering problem ?????? Vote_rcap
tjt603
6 posters
tjt603
tjt603
Steering problem ?????? Empty
PostSubject: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 2:17 pm
I have noticed that when driving straight my steering wheel is either a little to the left or right. what can I look for to make sure everything is ok.
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 2:42 pm
First thing to do is move the steering wheel back and forth about 1 - 2 in and see if the there is any slack. If no slack, do a front end alignment. If there is, have someone move the steering wheel back and forth for You and check the tie rod ends.
Then let us know what You find.
Dizzledog1
Dizzledog1
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 3:01 pm
Mine moves quite a bit back n fourth. I figured it was some kind of bushing. Am I mistaken?
thekrust
thekrust
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 3:04 pm
Wheel bearings can also cause this. Jack up the front end and see if there is any wobble.
tjt603
tjt603
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 3:05 pm
I have brand new wheel bearings and new tie rods.
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 3:21 pm
I would also cheak the joints in the steering shaft.
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 4:10 pm
sounds like it may be the steering assembly.....
PostSubject: Re: Steering problem ??????   Steering problem ?????? Icon_minitimeTue May 28, 2013 6:30 pm
Make sure tie rods inners and outers, balljoints are all fully seated,next when your wheel is straight ahead,rock the steering wheel just a little left to right before you see wheel movement.
If that looks good check your rack to colum pinch bolt for tightness, after have a look at your control arm bushings if they pass then you should check your toe. There is a good video made by James in which he uses the rears for you fixed point then checks. If the tire pressures are set try a level and check the vertical for positive or negative camber. If after everything checks good, there is only frame damage or a serious roadcrown, off camber.(all measurements are done after the tire pressures and on flat level ground). Good luck.
» Got a problem
» Power Steering?
» Problem with hood clips
» Rhino 700 Electrical Problem - Solved!
» Steering box
