| Problem with hood clips | |
+9ChrisH madmax 1 honda450sfm RhinoGT350 Hump mike734 ASPENDELLROVER CUSTOMIZEDRHINO13 thekevin 13 posters |
| Subject: Problem with hood clips Sun Jul 07, 2013 1:03 am | |
| Do any of you guys have an issue with your hoods popping out of place when you ride hard. Mine keeps shifting forward and popping the two tabs at the top out of the dash and those tabs ride up on my dash and I have to keep pulling over and popping them in place. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 1:38 am | |
| Mine doesn't go in at all. Maybe one side goes in. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 2:42 am | |
| no problem here, but I have +6 LT w/ kings, alot smoother ride... could be all your HP, ask T. Rhino aka "Mr. HP" | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 10:08 am | |
| - ASPENDELL ROVER wrote:
- no problem here, but I have +6 LT w/ kings, alot smoother ride... could be all your HP, ask T. Rhino aka "Mr. HP"
im sorry all I see is bla bla bla I have +6 LT w/ kings, a lot smother ride bla bla bla.......where are the slapping smilies | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 10:09 am | |
| I haven't had that problem. Those tabs barely go in the holes on mine, I don't know how they stay in. They get on my nerves a little. I've been wondering if I would get any vibration noise if I trimmed them off. | |
RhinoGT350
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 10:35 am | |
| no i never had that issue with mine | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 10:42 am | |
| Yes mine pops all the time on my 660. Especially when I hit deep water fast and the water pressure pushes up on the hood. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 11:23 am | |
| Mine mostly does it at high speeds if I I hit something that bottoms my suspension out. I was thinking about buying a couple of the pins and rubber latches that are on the sides and putting them on each side of the hump on the top of the hood connected to the dash. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 11:35 am | |
| are your rubber straps getting weak | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 11:45 am | |
| I hope not, my rhino is only about 4 months old. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 3:42 pm | |
| Mine does this, exactly what you are talking about. It's super annoying. It's like the tabs aren't quite long enough. My half-assed fix was to put a small strip of adhesive foam insulation on the dash panel, the kind about a wide as that flat area. It makes the hood vibrate less and makes those tabs much tighter in the groove. | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 6:14 pm | |
| I cant even get mine to go inside the little holes.... I just leave it undone and live with it.... it will only pop up a little bit,, extra streamline cooling cause the hot air can come out lol.... just go faster | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 6:18 pm | |
| my buddy's pooplaris does not have this problem, maybe we should sell our rhino's.... | |
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 9:38 pm | |
| I was thinking maybe some hood pins would fix it, and they add what like 25hp or something right | |
willykiller
Posts : 5 Join date : 2013-03-12 Location : Ottawa, Canada
| Subject: Re: Problem with hood clips Sun Jul 07, 2013 10:48 pm | |
| Too much air pressure under the hood from forward motion will cause the hood to pop open..... | |
| Subject: Re: Problem with hood clips Tue Jul 09, 2013 4:05 pm | |
| I guess the only thing that sucks about it is when those tabs pop up they ride on top of my cowl and scratch it up. I guess I could just cut them off and see if affects how my hood stays shut. | |
Tunderslimer
| Subject: Re: Problem with hood clips Tue Jul 09, 2013 4:27 pm | |
| Mine does this too. Scratchin all my purdy paint. | |
| Subject: Re: Problem with hood clips Wed Jul 10, 2013 3:39 am | |
| I like the hood pin idea. I know you don't need to lock your hood, but the ones that take the key don't stick up hardly any and have a nice low profile look to them. You could put them about 10" or so from the center in the back and they would look ok. Hood would not move at all then. | |
| Subject: Re: Problem with hood clips Wed Jul 10, 2013 12:04 pm | |
| willykiller you weren't joking about the air pressure under the hood pushing them up. I had my tabs pop out last night a couple of times and at 60mph my hood was probably 3 inches above the cowl. It's time to kick this problem in the arse. | |
| Subject: Re: Problem with hood clips Wed Jul 10, 2013 12:26 pm | |
| mine are about wore off and my hood has about wore a hole in my cage | |
| Subject: Re: Problem with hood clips | |
