In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests
Under my hood Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Under my hood Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Under my hood Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Under my hood Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Under my hood Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Under my hood Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Under my hood Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Under my hood Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Under my hood Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Under my hood Vote_lcapUnder my hood Voting_barUnder my hood Vote_rcap
 Under my hood
meats
14 posters
Go to page : 1, 2  Next
Under my hood Empty
PostSubject: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 1:49 pm
Here is a pic under my hood showing the oil cooler relocation with my heater under it.
Under my hood Under_11
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 1:52 pm
look clean, makes me wanna clean mine more..lol
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:00 pm
Very clean looking steve! Looks brand new, hard to believe its an 06!
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:03 pm
Thanks, it also has 6000 hard miles on it.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:07 pm
Thats top notch!! i can see that your a stickler for neatness!...nice set up
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:10 pm
Looks awsome very neatly put together.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:13 pm
With this setup, my oil capacity increased from the 2.25 quarts to 4.5 qts. I can change the filter assembly and increase it to 5.5 qts.
The coolant capacity has also been increased from .5 gallons to 1 gallon.
I believe more is better, especially with how hard I run mine.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 2:57 pm
man that's a clean ride , I agree about added capacity for cooling (water or oil) are those Russell fitings on your oil cooler ....how did you connect to the factory oil lines going back to moter
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 3:01 pm
man that is nice , clean also, I totally agree with you about the increase capacities nice work
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 3:33 pm
The fittings and hoses are AN 8 from Fragola. I welded an adapters onto the cooler lines under the air filter. The factory flair fits perfect with the AN adapter bung. No restriction at all. Each stainless braided hose is about 5 ft long.
http://fragolaperformancesystems.com/
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 3:37 pm
I'm trying to post more pics but having trouble!
You can see the temp sensor for the gauge, it's looking towards the pass side. Next to it looking up is the temp sensor that controls the fan to the cooler.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 4:08 pm
another pic
Under my hood Oil_co10
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 5:32 pm
That looks nice and gives me an idea.
What do you think about using a trans cooler for a larger oil cooler ? I have the old cooling fan off my grizzly that I can use too. I need to clean out the oil cooler since the wet clutch went and it looks like I got crap in the oil.
http://www.trailbrightled.com
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 8:22 pm
Awesome setup!!!
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 8:29 pm
Im going to do something like that to increase my oil capacity!!
meats
meats
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 8:52 pm
nice setup. if only i had the patience to do that.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 8:58 pm
Yes, you can use a tyrannies cooler.
Here is what I used
http://www.summitracing.com/parts/der-15850
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 9:01 pm
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 9:23 pm
how about a picture of the rhino------------------i gotta see it.
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSun Apr 28, 2013 11:25 pm
Yea No Shit!
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeMon Apr 29, 2013 9:40 am
I also run a filter magnet to aid in capturing any particles. It's to bad these arent dry sumped. Not a fan of wet clutch sharing the engine oil!
Bumpers
Bumpers
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSat May 04, 2013 3:14 pm
very nice
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSat May 04, 2013 3:19 pm
Thanks, I have a Maier hood scoop that feeds air to it. The fan has a switch that is thermostatically controlled. It doesn't run much at speed. The cooler came from Summit and is a Derale Atomic cooler. 2 years and 2500 miles and no issues!
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeSat May 04, 2013 6:06 pm
Steve that's some of the neatest under hood set-up I have ever seen, excellent work shows you take pride in your ride
Under my hood Empty
PostSubject: Re: Under my hood   Under my hood Icon_minitimeFri May 10, 2013 9:42 am
nice!!
Under my hood Empty
Under my hood
» how to avoid hood humping
» Problem with hood clips
» The first Rhino hood ornament
