In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 1 Bot
Secondary sheave removal.... Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Secondary sheave removal.... Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Secondary sheave removal.... Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Secondary sheave removal.... Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Secondary sheave removal.... Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Secondary sheave removal.... Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Secondary sheave removal.... Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Secondary sheave removal.... Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Secondary sheave removal.... Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Secondary sheave removal.... Vote_lcapSecondary sheave removal.... Voting_barSecondary sheave removal.... Vote_rcap
4 posters
FLOGROWN
FLOGROWN
Secondary sheave removal.... Empty
PostSubject: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeTue Jul 30, 2013 8:49 pm
How in the hell do I get the secondary off my 660, yes I watched the video, I have a come along pullin on my motor to the max and that fucker still won't come out, what am I missing here
Gyrene
Gyrene
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeTue Jul 30, 2013 9:45 pm
Is the nut off and you're trying to get the sheave off the shaft? Or are you trying to get the nut broke loose?
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeTue Jul 30, 2013 10:11 pm
The nut was off, I was trying to get the sheave off the shaft, got that off now, who's bright idea was it to put that brace there. Now I'm trying to get the nut to break free from the wet clutch, got the drum housing off just need to get the 1" nut off now to pull the wet clutch. It's one thing after another I tell ya.
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 12:47 am
I think that nut on the wet clutch is reverse thread.....
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 12:54 am
I know the 660 and the 700 are opposite I'm just not sure which witch is which
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 1:18 am
my 700  was reverse thread...
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 2:47 am
That helps then so the 660 is standard thread, how hard was it to break free? Any secrets? It's my last nut and in at the home stretch..
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 9:54 am
once I figured out out was reverse... not bad with a  impact gun
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 12:29 pm
Thanks, did you ever figure out why u were only getting 35 mph?
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 2:06 pm
yeah kinda,  it's better  but not adjust it should be..
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 8:48 pm
 I had the same problem with mine and ended up cutting that section out and welding some 1'' flat steel tabs to the section that I cut out and drilled 3/8'' holes so I could bolt it back in,now I just take 2 bolts out and waalaa the secondary comes right out without cussing!!cheers
Gyrene
Gyrene
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 10:45 pm
 Great idea Mike!!!
FLOGROWN, Did you get both rhinos finished????
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 10:52 pm
That's right...we will overcome!!
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 11:44 pm
Gyrene wrote:
 Great idea Mike!!!
No not yet, kits should be here tomorrow, but opened up wet clutch cover to get ready for slugs, sent pics to James and he said its on its last leg so I ordered a new one today for the 660. He said it will ship today and hopefully by Friday I have it. If not Monday it is. I HATE WAITING FOR SANTA...santa
FLOGROWN
FLOGROWN
PostSubject: Re: Secondary sheave removal....   Secondary sheave removal.... Icon_minitimeWed Jul 31, 2013 11:46 pm
Mike that is a pretty good idea, might get out the welder and fab something up. I don't know who the genius was to weld a bar there that can't be removed for easy servicing of the clutch but he should be fired.
» Secondary spring removal?
» any write ups on sheave removal
» any trick to sheave nut removal
» how to get the secondary sheave out on a 660
» Secondary Sheave grease
