In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 1 Bot
ROD Side Play Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
ROD Side Play Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
ROD Side Play Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
ROD Side Play Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
ROD Side Play Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
ROD Side Play Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
ROD Side Play Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
ROD Side Play Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
ROD Side Play Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
ROD Side Play Vote_lcapROD Side Play Voting_barROD Side Play Vote_rcap
 ROD Side Play
Shevalik
ROD Side Play Empty
PostSubject: ROD Side Play   ROD Side Play Icon_minitimeTue Jul 30, 2013 10:57 pm
What is an acceptable amount of side play in the rod. I measured the space between the bottom of the rod and flywheel and it is within acceptable tolerances. But i just am curious if that measurement is good, is it safe to assume the amount of side play is good? If not, what is an acceptable amount of play and how do you measure it?
ROD Side Play
» Got out out play this weekend
» Came over from the dark side...
» side engine fan
» hello i made it to the dark side
» Side Steps/Nerf bar $50
